[mapserver-users] OGRVRT Data Sources and SQL server
Chris Jackson
webturtles at gmail.com
Wed May 30 05:42:27 PDT 2012
Hi Robert and Jeff
I tried those steps (think FID is optional) and no further - more blank
outputs using shp2img (ms bebugging at 5 - no errors at all, happily finds
layer and draws it - apparently! - should rename my layer to snowflakes or
white cats....). Have run shp2img debugging - nothing obvious, but
couldn't print out output (can send screenshot if anyone interested). Not
sure how to retrieve the sql query sent (Jeff?).
I have grabbed the output from ogrinfo (see below - no extents...does that
mean something) - seems to be working ok to the untrained eye! Mapfile
below too (NB. have tried with and without projections at map and layer
level), I am baffled, will start to use a later version of ms4w and check
on another server too.
Cheers
Chris
ogrinfo output:
INFO: Open of `d:/xxx/xxx/omreg2.ovf'
using driver `VRT' successful.
Layer name: omreg1
Geometry: Point
Feature Count: 5
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
SiteKeyID: Integer (10.0)
SiteID: Integer (10.0)
SiteType: String (255.0)
SiteName: String (255.0)
SiteLat: Real (0.0)
SiteLong: Real (0.0)
OGRFeature(omreg1):1
SiteKeyID (Integer) = 2269
SiteID (Integer) = 1
SiteType (String) = Regulated tidal exchange
SiteName (String) = Abbotts Hall (Stage 1)
SiteLat (Real) = 0.84556009184722
SiteLong (Real) = 51.7846475991705
POINT (51.784647599170498 0.84556009184722)
My mapfile now is this:
MAP
UNITS meters
EXTENT -15 30 40 70
SIZE 600 500
SHAPEPATH "d:\xxx\xxx\"
SYMBOLSET "../common/symbols/symbols-pmapper.sym"
FONTSET "../common/fonts/msfontset.txt"
RESOLUTION 96
IMAGETYPE png
INTERLACE OFF
CONFIG "PROJ_LIB" "D:\xxx\proj\nad\"
CONFIG "GDAL_DATA" "D:\xxx\gdaldata\"
CONFIG "MS_ERRORFILE" "D:\xxxxx\tmp\ms_error.txt"
DEBUG 5
PROJECTION
#"init=epsg:4326"
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs no_defs"
END
# Image formates for GD
OUTPUTFORMAT
NAME "png"
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
FORMATOPTION INTERLACE=OFF
TRANSPARENT OFF
EXTENSION "png"
END
OUTPUTFORMAT
NAME "png8"
DRIVER "GD/PNG"
IMAGEMODE PC256
TRANSPARENT OFF
EXTENSION "png"
END
OUTPUTFORMAT
NAME "jpeg"
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
FORMATOPTION "QUALITY=70"
EXTENSION "jpg"
END
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE RGB
FORMATOPTION "TFW=YES"
#FORMATOPTION "COMPRESS=PACKBITS"
EXTENSION "tif"
END
OUTPUTFORMAT
NAME imagemap
MIMETYPE "text/html"
FORMATOPTION SKIPENDTAG=OFF
DRIVER imagemap
END
LAYER
NAME "test"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "omreg2.ovf" # have also tried ./omreg2.ovf - both files in
same folder - no luck with either
DATA "omreg1"
PROJECTION
#"init=epsg:4326"
END
STATUS ON
CLASS
SYMBOL 1
SIZE 6
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END
END #Map
On 29 May 2012 21:54, Robert Sanson <Robert.Sanson at asurequality.com> wrote:
> Hi Chris
> You need to define the primary key in your .ovf file:
> <FID>farmgate_id</FID>
> I put the .ovf file in the same directory as my .map file, then Mapserver
> can find it:
> CONNECTION "./farmgates.ovf"
> All thebest,
> Robert
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120530/286b59da/attachment.html>
