[mapserver-users] tinyows
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Fri Nov 2 02:21:25 PDT 2012
You must capture the traffic between OpenLayers and TinyOWS.  I am using myself Fiddler2 proxy but I suppose that Firebug can show you what OpenLayers is sending and high enough TinyOWS logging level will also gather requests into tinyows log. The software is not important but you just have to get the requests so you can resend them with a browser or some other tool that yuo can control and see what happens. You can also include the requests in your further mails. Then the question will be "OpenLayers is sending this and TinyOWS is sending back that, what's wrong?" and it will be much easier to answer.
As always with WFS, start with these requests with a browser before doing anything with OpenLayers:
http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetCapabilities&version=1.1.0
http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment
http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetFeature&version=1.1.0&typename=water:pipeline_segment&maxFeatures=10
If all those requests work you know that TinyOWS works with those basic requests and if OpenLayers application does not get data the reason in probably in the application code.
-Jukka Rahkonen-
aho wrote:
> hello!
> I have a problem with the configuration of tinyows. I have the following
settings in my xml file:
> <tinyows online_resource="localhost/cgi-bin/tinyows.exe"
        schema_dir="C:\ms4w\apps\tinyows\schema\">
<pg host="localhost" user="postgres" password="postgres"
dbname="watergis" port="5432"/>
<metadata name="TinyOWS Server"
           title="TinyOWS Server - WFS-T Frida Service" />
<contact name="TinyOWS Server"
          site="http://www.tinyows.org/"
          email="tinyows-users at lists.maptools.org" />
<layer retrievable="1"
        writable="1"
        ns_prefix="water"
        ns_uri="http://localhost/"
        name="pipeline_segment"
        title="pipeline_segment"
        table= "pipeline_segment"
        srid="32740"
        schema="water"/>
</tinyows>
 >if I enter tinyows --check I get the following back:
> C:\ms4w\Apache\cgi-bin>tinyows --check
TinyOWS version:   1.0.0rc3
FCGI support:      Yes
Config File Path:  C:\ms4w\apps\tinyows\tinyows.xml (TinyOWS XML)
PostGIS Version:   2.0.0
PostGIS dsn:       host=localhost user=postgres password=postgres
dbname=watergi
s port=5432
Output Encoding:   UTF-8
Database Encoding: UTF8
Schema dir:        C:\ms4w\apps\tinyows\schema\
Display bbox:      Yes
Estimated extent:  No
Check schema:      Yes
Check valid geoms: Yes
Available layers:
  - water.pipeline_segment (32740) -> water.pipeline_segment [RW]
> which looks acutally quite good. But when i am trying to include that
into my openlayer map - I always get 0 features back! Here the code for
openlayers:
wfs = new OpenLayers.Layer.Vector("Editable Features", {
         strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
         projection: new OpenLayers.Projection("EPSG:31467"),
         protocol: new OpenLayers.Protocol.WFS({
               version: "1.1.0",
               srsName: "EPSG:32740",
               url: "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe",
               featureNS :  "tows",
               featureType: "pipeline_segment",
               geometryName: "geometry",
               schema:
"http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment"
Someone an idea?
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
