[mapserver-users] tinyows
aho
forum.email.a at googlemail.com
Fri Nov 2 08:15:20 PDT 2012
Hello,
thanks for the suggestion, I think I am a step further!
But here is the next problem: I found something that could make a problem:
http://127.0.0.1:8000/WNT/proxy.cgi?url=http%3A%2F%2Flocalhost%3A8000%2Fredir%2Fcgi-bin%2Ftinyows.exe
500 (Internal Server Error)
what do I need to set in the prox.cgi and for what is the
OpenLayers.ProxyHost = "proxy.cgi?url=" good?
Could that be the problem?
Am 11/2/2012 3:29 PM, schrieb Serge Dikiy:
> Hi,
> http://translate.google.com/translate?sl=ru&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fgis-lab.info%2Fforum%2Fviewtopic.php%3Ff%3D41%26t%3D10329
> BR
> On Fri, Nov 2, 2012 at 4:15 PM, aho <forum.email.a at googlemail.com> wrote:
>> Hi Jukka,
>> ok, I solved the problem with the requests. The following returns from
>> tinyOWS:
>> <?xml version='1.0' encoding='UTF-8'?>
>> <ows:ExceptionReport
>> xmlns='http://www.opengis.net/ows'
>> xmlns:ows='http://www.opengis.net/ows'
>> xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
>> xsi:schemaLocation='http://www.opengis.net/ows
>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd'
>> version='1.1.0' language='en'>
>> <ows:Exception exceptionCode='InvalidParameterValue' locator='request'>
>> <ows:ExceptionText>XML request isn't valid</ows:ExceptionText>
>> </ows:Exception>
>> </ows:ExceptionReport>
>> Here is the errorlog:
>> Fri Nov 02 15:11:46 2012] [EVENT] == FCGI START ==
>> [Fri Nov 02 15:11:46 2012] [QUERY] <wfs:GetFeature
>> xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0"
>> xsi:schemaLocation="http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd water
>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetFeature&version=1.0.0&typename=water:armature"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Query
>> typeName="feature:armature" xmlns:feature="water"><ogc:Filter
>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box
>> xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:32740"><gml:coordinates
>> decimal="." cs="," ts=" ">-2866.3885602952,-1910.9257068634
>> 2866.3885602952,1910.9257068634</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter></wfs:Query></wfs:GetFeature>
>> [Fri Nov 02 15:11:46 2012] [ERROR] Element
>> '{http://www.w3.org/2001/XMLSchema}import': Failed to locate a schema at
>> location
>> 'localhost/cgi-bin/tinyows.exe?service=WFS&request=DescribeFeatureType&version=1.0.0'.
>> Skipping the import.
>> '{http://www.opengis.net/wfs}GetFeature': No matching global declaration
>> available for the validation root.
>> [Fri Nov 02 15:11:46 2012] [ERROR] XML request isn't valid
>> [Fri Nov 02 15:11:46 2012] [EVENT] == FCGI SHUTDOWN ==
>> [Fri Nov 02 15:11:46 2012] [EVENT] == TINYOWS SHUTDOWN ==
>> Has it something to do with the schema? I found a post with something
>> similar
>> (http://osgeo-org.1560.n6.nabble.com/TinyOWS-wrong-call-in-OpenLayers-InvalidParameterValue-XML-request-isn-t-valid-td5009059.html)
>> and replaced all my old tinyows files and copied the ones from the ms4w
>> homepage.
>> Do you have some more ideas?
>> Am 11/2/2012 10:56 AM, schrieb Rahkonen Jukka:
>> Hi,
>> Yes, it seems to be OpenLayers question then. However, do still capture the
>> requests because without them you cannot understand what happens really. My
>> guess is that something in wrong in how EPSG:31467 and EPSG:32740 are used
>> and OpenLayers is requesting data from a place where there are no data.
>> -Jukka-
>> aho wrote:
>> Hi Jukka,
>> thanks a lot for your answer and the good tips! I tried all of the links
>> and they are working. Also I checked it in QGIS and there I can load it
>> too.
>> So I guess it will be better to write again to the openlayers mailinglist?!
>> Am 11/2/2012 10:21 AM, schrieb Rahkonen Jukka:
>> Hi,
>> You must capture the traffic between OpenLayers and TinyOWS. I am using
>> myself Fiddler2 proxy but I suppose that Firebug can show you what
>> OpenLayers is sending and high enough TinyOWS logging level will also gather
>> requests into tinyows log. The software is not important but you just have
>> to get the requests so you can resend them with a browser or some other tool
>> that yuo can control and see what happens. You can also include the requests
>> in your further mails. Then the question will be "OpenLayers is sending this
>> and TinyOWS is sending back that, what's wrong?" and it will be much easier
>> to answer.
>> As always with WFS, start with these requests with a browser before doing
>> anything with OpenLayers:
>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetCapabilities&version=1.1.0
>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment
>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetFeature&version=1.1.0&typename=water:pipeline_segment&maxFeatures=10
>> If all those requests work you know that TinyOWS works with those basic
>> requests and if OpenLayers application does not get data the reason in
>> probably in the application code.
>> -Jukka Rahkonen-
>> aho wrote:
>> hello!
>> I have a problem with the configuration of tinyows. I have the following
>> settings in my xml file:
>> <tinyows online_resource="localhost/cgi-bin/tinyows.exe"
>> schema_dir="C:\ms4w\apps\tinyows\schema\">
>> <pg host="localhost" user="postgres" password="postgres"
>> dbname="watergis" port="5432"/>
>> <metadata name="TinyOWS Server"
>> title="TinyOWS Server - WFS-T Frida Service" />
>> <contact name="TinyOWS Server"
>> site="http://www.tinyows.org/"
>> email="tinyows-users at lists.maptools.org" />
>> <layer retrievable="1"
>> writable="1"
>> ns_prefix="water"
>> ns_uri="http://localhost/"
>> name="pipeline_segment"
>> title="pipeline_segment"
>> table= "pipeline_segment"
>> srid="32740"
>> schema="water"/>
>> </tinyows>
>> >if I enter tinyows --check I get the following back:
>> C:\ms4w\Apache\cgi-bin>tinyows --check
>> TinyOWS version: 1.0.0rc3
>> FCGI support: Yes
>> Config File Path: C:\ms4w\apps\tinyows\tinyows.xml (TinyOWS XML)
>> PostGIS Version: 2.0.0
>> PostGIS dsn: host=localhost user=postgres password=postgres
>> dbname=watergi
>> s port=5432
>> Output Encoding: UTF-8
>> Database Encoding: UTF8
>> Schema dir: C:\ms4w\apps\tinyows\schema\
>> Display bbox: Yes
>> Estimated extent: No
>> Check schema: Yes
>> Check valid geoms: Yes
>> Available layers:
>> - water.pipeline_segment (32740) -> water.pipeline_segment [RW]
>> which looks acutally quite good. But when i am trying to include that
>> into my openlayer map - I always get 0 features back! Here the code for
>> openlayers:
>> wfs = new OpenLayers.Layer.Vector("Editable Features", {
>> strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
>> projection: new OpenLayers.Projection("EPSG:31467"),
>> protocol: new OpenLayers.Protocol.WFS({
>> version: "1.1.0",
>> srsName: "EPSG:32740",
>> url: "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe",
>> featureNS : "tows",
>> featureType: "pipeline_segment",
>> geometryName: "geometry",
>> schema:
>> "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment"
>> Someone an idea?
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121102/53f277a6/attachment-0001.html>
