[mapserver-users] OGR & MSSQL Server on specified Port Number fails to connect
Tamas Szekeres
szekerest at gmail.com
Tue Nov 6 00:06:58 PST 2012
David,
This might indeed be a bug in the OGR driver. Just file a ticket for that
in the GDAL issue tracker <http://trac.osgeo.org/gdal/newticket>.
Best regards,
Tamas
2012/11/6 David Martin <David at itbeyond.com.au>
> Hi,****
> I have a geodata source on SQLServer 2008 and have been using for a number
> of years the msplugin_mssql2008.dll plugin. I now want to use some stored
> procedures in my SQL server to render the geo data to MapServer. So I have
> been working with the OGR driver however I have found what I think is a
> problem when the SQL server is on a none standard TCP port as the comma in
> the server definition gets thrown away when rendering the layer using a map
> file via shp2img. I can use ogrinfo without problem but as soon as I carry
> the string to the OGR layer in the .map file and run shp2img –all_debug 1 I
> see that the tcp port of my SQL server is removed and hence the connection
> fails. ****
> So the working OGR syntax is:****
> ogrinfo "MSSQL:uid=xxx;pwd=xxx;database=xxx;Integrated
> Security=false;server=MY_WEB-SqlServer.com,4670;tables=PointPlace_Waypoints(Position)"
> -summary****
> INFO: Open of `MSSQL:uid=xxx;pwd=xxx;database=xxx;Integrated
> Security=false;server=MY_WEB-SqlServer.com,4670;tables=PointPlace_Waypoints(Position)'
> using driver `MSSQLSpatial' successful.****
> 1: PointPlace_Waypoints****
> NOTE: The TCP Port is 4670 – this is the same as used in the mssql2008.dll
> plug in.****
> When I use shp2img this is what I get:****
> shp2img -m latest.map -o test.png -all_debug 1****
> msDrawMap(): rendering using outputformat named png (AGG/PNG8).****
> msOGRFileOpen(MSSQL:uid=xxx;pwd=xxx;database=xxx;Integrated
> Security=false;server=MY_WEB-SqlServer.com,4670)...****
> OGROPen(MSSQL:uid=xxx;pwd=xxx;database=xxx;Integrated
> Security=false;server= MY_WEB-SqlServer.com)****
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
> `latest1'.****
> Unable to initialize connection to the server for
> MSSQL:uid=xxx;pwd=xxx;database=xxx;Integrated Security=false;server=
> MY_WEB-SqlServer.com,****
> [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or
> access denied.****
> msDrawMap(): Image handling error. Failed to draw layer named 'latest1'.**
> <br>****
> `latest1'.****
> access denied.****
> You will notice that two lines:****
> The system is calling msOGRFileOpen with a ,4670 but the OGROPen has
> removed the comma and tcp port number hence my connection fails.****
> Is there a resolution to this or is there another way to execute stored
> procedures with MapServer layers?****
> David****
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121106/73343048/attachment.html>
