[mapserver-users] [TinyOWS] Inserting feature and XML schema validation
Olivier Courtin
olivier.courtin at gmail.com
Wed Nov 7 10:24:24 PST 2012
On Wed, Nov 7, 2012 at 5:13 PM, Тимур Галиаскарович Суфиев <t.sufiev at acti.ru
> wrote:
Hi Timur,
> This isn't the first question here about inserting features in TinyOWS,
> but I haven't found solution to my problem in archives.
> and this xsd should make tinyows use element '{http://www.tinyows.org}cities'
> like '{http://www.opengis.net/gml}_Feature'
> Where am I wrong and what should be changed in my setup?
Thanks for your detailled report,
first naive question, what about the tinyows.xml config file,
and online_resource property ?
Next question, what happen, if you bypass schema validation,
with: check_schema = "0" (in tinyows element)
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121107/b83e5681/attachment.html>
