[mapserver-users] tinyows
aho
forum.email.a at googlemail.com
Fri Nov 9 01:27:04 PST 2012
Hi again,
I am still searching and not finding something. I setup everything again
with the WFS-T tutorial. Now I am getting the following error message:
[Thu Nov 08 16:32:21 2012] [ERROR] local list type: A type, derived by
list or union, must have the simple ur-type definition as base type, not
'{http://www.opengis.net/gml}doubleOrNullList'.
Am I right with this forum? Because actually nobody replies.
Am 11/6/2012 1:30 PM, schrieb aho:
> Hey,
> I still havn´t found the problem with the tinyows - but at the moment
> there is no error message when i am loading the wfs. Also fiddler
> doesn´t list the tinyows.exe anymore. But my proxy is correct - I can
> load it via uDig and ArcMap. QGIS has a problem, but there is not a
> single error in the tinyows log file - just events and sqls are
> listed, that looks quite good. With Open layers there is nothing
> logged - it seems like the request is not send.
> Is there any limitation for the version? I downloaded the latest
> (2.12) one, but on the tinyows page is version 2.09 listed?!
> Kind regards
> Am 11/2/2012 3:29 PM, schrieb Serge Dikiy:
>> Hi,
>> http://translate.google.com/translate?sl=ru&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fgis-lab.info%2Fforum%2Fviewtopic.php%3Ff%3D41%26t%3D10329
>> BR
>> On Fri, Nov 2, 2012 at 4:15 PM, aho <forum.email.a at googlemail.com>
>> wrote:
>>> Hi Jukka,
>>> ok, I solved the problem with the requests. The following returns from
>>> tinyOWS:
>>> <?xml version='1.0' encoding='UTF-8'?>
>>> <ows:ExceptionReport
>>> xmlns='http://www.opengis.net/ows'
>>> xmlns:ows='http://www.opengis.net/ows'
>>> xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
>>> xsi:schemaLocation='http://www.opengis.net/ows
>>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd'
>>> version='1.1.0' language='en'>
>>> <ows:Exception exceptionCode='InvalidParameterValue'
>>> locator='request'>
>>> <ows:ExceptionText>XML request isn't valid</ows:ExceptionText>
>>> </ows:Exception>
>>> </ows:ExceptionReport>
>>> Here is the errorlog:
>>> Fri Nov 02 15:11:46 2012] [EVENT] == FCGI START ==
>>> [Fri Nov 02 15:11:46 2012] [QUERY] <wfs:GetFeature
>>> xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0"
>>> xsi:schemaLocation="http://www.opengis.net/wfs
>>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd water
>>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetFeature&version=1.0.0&typename=water:armature"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><wfs:Query
>>> typeName="feature:armature" xmlns:feature="water"><ogc:Filter
>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box
>>> xmlns:gml="http://www.opengis.net/gml"
>>> srsName="EPSG:32740"><gml:coordinates
>>> decimal="." cs="," ts=" ">-2866.3885602952,-1910.9257068634
>>> 2866.3885602952,1910.9257068634</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter></wfs:Query></wfs:GetFeature>
>>> [Fri Nov 02 15:11:46 2012] [ERROR] Element
>>> '{http://www.w3.org/2001/XMLSchema}import': Failed to locate a
>>> schema at
>>> location
>>> 'localhost/cgi-bin/tinyows.exe?service=WFS&request=DescribeFeatureType&version=1.0.0'.
>>> Skipping the import.
>>> '{http://www.opengis.net/wfs}GetFeature': No matching global
>>> declaration
>>> available for the validation root.
>>> [Fri Nov 02 15:11:46 2012] [ERROR] XML request isn't valid
>>> [Fri Nov 02 15:11:46 2012] [EVENT] == FCGI SHUTDOWN ==
>>> [Fri Nov 02 15:11:46 2012] [EVENT] == TINYOWS SHUTDOWN ==
>>> Has it something to do with the schema? I found a post with something
>>> similar
>>> (http://osgeo-org.1560.n6.nabble.com/TinyOWS-wrong-call-in-OpenLayers-InvalidParameterValue-XML-request-isn-t-valid-td5009059.html)
>>> and replaced all my old tinyows files and copied the ones from the ms4w
>>> homepage.
>>> Do you have some more ideas?
>>> Am 11/2/2012 10:56 AM, schrieb Rahkonen Jukka:
>>> Hi,
>>> Yes, it seems to be OpenLayers question then. However, do still
>>> capture the
>>> requests because without them you cannot understand what happens
>>> really. My
>>> guess is that something in wrong in how EPSG:31467 and EPSG:32740
>>> are used
>>> and OpenLayers is requesting data from a place where there are no data.
>>> -Jukka-
>>> aho wrote:
>>> Hi Jukka,
>>> thanks a lot for your answer and the good tips! I tried all of the
>>> links
>>> and they are working. Also I checked it in QGIS and there I can load it
>>> too.
>>> So I guess it will be better to write again to the openlayers
>>> mailinglist?!
>>> Am 11/2/2012 10:21 AM, schrieb Rahkonen Jukka:
>>> Hi,
>>> You must capture the traffic between OpenLayers and TinyOWS. I am using
>>> myself Fiddler2 proxy but I suppose that Firebug can show you what
>>> OpenLayers is sending and high enough TinyOWS logging level will
>>> also gather
>>> requests into tinyows log. The software is not important but you
>>> just have
>>> to get the requests so you can resend them with a browser or some
>>> other tool
>>> that yuo can control and see what happens. You can also include the
>>> requests
>>> in your further mails. Then the question will be "OpenLayers is
>>> sending this
>>> and TinyOWS is sending back that, what's wrong?" and it will be much
>>> easier
>>> to answer.
>>> As always with WFS, start with these requests with a browser before
>>> doing
>>> anything with OpenLayers:
>>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetCapabilities&version=1.1.0
>>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment
>>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=GetFeature&version=1.1.0&typename=water:pipeline_segment&maxFeatures=10
>>> If all those requests work you know that TinyOWS works with those basic
>>> requests and if OpenLayers application does not get data the reason in
>>> probably in the application code.
>>> -Jukka Rahkonen-
>>> aho wrote:
>>> hello!
>>> I have a problem with the configuration of tinyows. I have the
>>> following
>>> settings in my xml file:
>>> <tinyows online_resource="localhost/cgi-bin/tinyows.exe"
>>> schema_dir="C:\ms4w\apps\tinyows\schema\">
>>> <pg host="localhost" user="postgres" password="postgres"
>>> dbname="watergis" port="5432"/>
>>> <metadata name="TinyOWS Server"
>>> title="TinyOWS Server - WFS-T Frida Service" />
>>> <contact name="TinyOWS Server"
>>> site="http://www.tinyows.org/"
>>> email="tinyows-users at lists.maptools.org" />
>>> <layer retrievable="1"
>>> writable="1"
>>> ns_prefix="water"
>>> ns_uri="http://localhost/"
>>> name="pipeline_segment"
>>> title="pipeline_segment"
>>> table= "pipeline_segment"
>>> srid="32740"
>>> schema="water"/>
>>> </tinyows>
>>> >if I enter tinyows --check I get the following back:
>>> C:\ms4w\Apache\cgi-bin>tinyows --check
>>> TinyOWS version: 1.0.0rc3
>>> FCGI support: Yes
>>> Config File Path: C:\ms4w\apps\tinyows\tinyows.xml (TinyOWS XML)
>>> PostGIS Version: 2.0.0
>>> PostGIS dsn: host=localhost user=postgres password=postgres
>>> dbname=watergi
>>> s port=5432
>>> Output Encoding: UTF-8
>>> Database Encoding: UTF8
>>> Schema dir: C:\ms4w\apps\tinyows\schema\
>>> Display bbox: Yes
>>> Estimated extent: No
>>> Check schema: Yes
>>> Check valid geoms: Yes
>>> Available layers:
>>> - water.pipeline_segment (32740) -> water.pipeline_segment [RW]
>>> which looks acutally quite good. But when i am trying to include that
>>> into my openlayer map - I always get 0 features back! Here the code for
>>> openlayers:
>>> wfs = new OpenLayers.Layer.Vector("Editable Features", {
>>> strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
>>> projection: new OpenLayers.Projection("EPSG:31467"),
>>> protocol: new OpenLayers.Protocol.WFS({
>>> version: "1.1.0",
>>> srsName: "EPSG:32740",
>>> url:
>>> "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe",
>>> featureNS : "tows",
>>> featureType: "pipeline_segment",
>>> geometryName: "geometry",
>>> schema:
>>> "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment"
>>> Someone an idea?
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
