[mapserver-users] SVG Symbol -v 6.0.3
Alexandre Dubé
adube at mapgears.com
Mon Nov 12 05:30:02 PST 2012
One more detail : some svg may not work and there's currently no way of
detecting them within MapServer. The issue is explained here:
https://github.com/mapserver/mapserver/issues/4518
I suggest you try the mapfile showing the issue as explained in the
ticket. It has a working svg file, so you could use it to test your
MapServer installed.
http://dl.mapgears.com/msbug/4518.tar.gz
Regards,
Alexandre
On 12-11-12 08:23 AM, Alexandre Dubé wrote:
> The SVG symbols support is a new feature available in MapServer 6.2.
> You also need it to be compiled with libsvg-cairo enabled, see
> http://mapserver.org/development/rfc/ms-rfc-73.html#backwards-compatibility-issues
> Regards,
> Alexandre
> On 12-11-09 12:05 PM, Fernando Norte wrote:
>> Hi all,
>> To use SVG Symbol I need the OUTPUT=SVG in my mapserver? I'm use the
>> 6.0.3 version.
>> And try to use the symbol in that way bellow, but doesn't show nothing:
>> SYMBOL
>> NAME "pont"
>> TYPE svg
>> IMAGE "symbols/pont.svg"
>> END
>> CLASS
>> STYLE
>> SYMBOL "pont_22"
>> END
>> END
>> Thanks,
>> *Fernando Norte*
>> Desenvolvedor SIGWeb
>> tel.(31) 2533.9900
>> cel.(31) 9119.8814
>> skype: fernandoglobalgeo
>> Endereço: Alameda do Ingá, 88, 6º andar, Vale do Sereno
>> Nova Lima/MG - CEP: 34.000-000
>> www.globalgeo.com.br <http://www.globalgeo.com.br/>
>> "O presente documento pode conter material confidencial ou seu sigilo
>> é protegido por lei.
>> Quaisquer informações nele contida são destinadas exclusivamente
>> ao(s) seu(s) destinatário(s)
>> não devendo em nenhuma hipótese ser repassado a terceiros".
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121112/1f6f6bb3/attachment.html>
