[mapserver-users] TinyOWS 1.1.0 release
Olivier Courtin
olivier.courtin at gmail.com
Tue Nov 13 16:55:55 PST 2012
Hi all,
The 1.1.0 TinyOWS version is out.
Source code: http://www.tinyows.org/release/tinyows-1.1.0.tar.bz2
>From 1.0.0 release the key point was to bugfixe, to improve again
performances
and strict OGC standard implementation, and few userland improvements
on config file.
1.1.0 Changelog:
- Add include_items and exclude_items config handling. To choose exactly
which columns to retrieve (Serge Dikiy)
- XSD max length and enumeration constraint handling (Serge Dikiy & Alan
Boudreault)
- First real support of typename namespace provided in request (Olivier
Courtin)
- Generate PK value using PostgresSQL DEFAULT value if present (Serge
Dikiy)
- Add pkey configuration in layer config. Usefull for instance when
retrieving data from a VIEW. (Serge Dikiy)
- Buffer copy performance improve (Serge Dikiy)
- Rewrite/fix max features handling (Olivier Courtin)
- Extent layer's properties allowed to inherit (Olivier Courtin)
- Several bugfixes as usual (special thanks to Andreas Peri, Serge Dikiy
and Jukka Rahkonen for detailled reports)
Documentation was also refresh, including the OpenLayers HowTo.
http://ci.mapserver.org/job/docsmaster/lastSuccessfulBuild/artifact/build/html/en/tinyows/index.html#tinyows
Enjoy,
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121114/42981d20/attachment.html>
