[mapserver-users] Compile mapserver with custom external libs
Alberto Asuero alasarr at gmail.com
Fri Nov 16 04:11:57 PST 2012
I've compiled mapserver 5.6.7 with a custom version of geos, postgis, gdal
and proj4.
Here is the configure command:
*./configure           --prefix=/usr/local/gis/mapserver-5.6.7
--with-pdf            --with-freetype       --with-agg
 --with-eppl           --with-proj=/usr/local/gis/proj-4.7.0
--with-threads        --with-sde
 --with-geos=/usr/local/gis/geos-3.2.2/bin/geos-config
--with-ogr=/usr/local/gis/gdal-1.9.2/bin/gdal-config
--with-gdal=/usr/local/gis/gdal-1.9.0/bin/gdal-config           --with-tiff
          --with-postgis=/usr/local/gis/postgresql-9.1.2/bin/pg_config
   --with-wfs            --with-wcs            --with-wmsclient
 --with-wfsclient      --with-sos            --with-fribidi-config --with-gd
Everything works fine but when I do:
"*ldd mapserv*" it says:
*libproj.so.0 => /usr/lib/libproj.so.0 (0xb7504000)*
*libgdal.so.1 => not found*
*libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0xb74ec000)*
*libpq.so.5 => /usr/lib/libpq.so.5*
Why these libraries don't use the path specified in the configure command.
it'd be make senses to me if ldd output looks like:
*libproj.so.0 => /usr/local/gis/proj-4.7.0/lib/libproj.so.0 (0xb7504000)*
*libgeos_c.so.1 => /**usr/local/gis/geos-3.2.2**/lib/libgeos_c.so.1
(0xb74ec000)*
What's wrong here?
Am I forced to do symbol links or set the custom libraries in LD_PATH?
Thanks!
  Alberto Asuero
Ingeniero Informático
  alberto.asuero at gstgis.com
654 190 888
   Rodio 35
41007 Sevilla
Spain
  T  +34  954 437 818
F  +34  955 110 441
 Visita nuestra web
 *www.gstgis.com*
 <http://www.gstgis.com/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121116/084411a3/attachment.html>
