[mapserver-users] Compile mapserver with custom external libs
Jeff Lake admin at michiganwxsystem.com
Fri Nov 16 04:42:37 PST 2012
I may be mistaken here,
But when you compiled geos, gdal,and pgsql you specified the install
path of the program.
the libraries will go where libraries are suppose to go eg '/usr/lib'
'/usr/local/lib' etc...
so other programs can find them..
-Jeff Lake
MichiganWxSystem.com
AllisonHouse.com
TheWeatherCenter.net
GRLevelXStuff.com
On 11/16/2012 7:29, Alberto Asuero wrote:
> What I've done is a wrapper with an export like that before:
> export LD_LIBRARY_PATH=/export
> LD_LIBRARY_PATH=/usr/local/gis/postgresql-9.1.2/lib:/usr/local/gis/geos-3.3.2/lib:/usr/local/gis/proj-4.7.0/lib:/usr/local/gis/gdal-1.9.0/lib/
> How can I tell mapserver to do it automatically in mapserv executable
> itself? Is that possible?
> Alberto Asuero
> Ingeniero Informático
> alberto.asuero at gstgis.com <mailto:alberto.asuero at gstgis.com>
> 654 190 888
> Rodio 35
> 41007 Sevilla
> Spain
> T  +34  954 437 818
> F  +34  955 110 441
> Visita nuestra web
> *www.gstgis.com*
> <http://www.gstgis.com/>
> On Fri, Nov 16, 2012 at 1:11 PM, Alberto Asuero <alasarr at gmail.com
> <mailto:alasarr at gmail.com>> wrote:
>     I've compiled mapserver 5.6.7 with a custom version of geos,
>     postgis, gdal and proj4.
>     Here is the configure command:
>     /./configure --prefix=/usr/local/gis/mapserver-5.6.7 --with-pdf
>              --with-freetype --with-agg            --with-eppl
>     --with-proj=/usr/local/gis/proj-4.7.0 --with-threads
>      --with-sde  --with-geos=/usr/local/gis/geos-3.2.2/bin/geos-config
>     --with-ogr=/usr/local/gis/gdal-1.9.2/bin/gdal-config
>     --with-gdal=/usr/local/gis/gdal-1.9.0/bin/gdal-config
>     --with-tiff
>     --with-postgis=/usr/local/gis/postgresql-9.1.2/bin/pg_config
>      --with-wfs            --with-wcs    --with-wmsclient
>      --with-wfsclient  --with-sos            --with-fribidi-config
>     --with-gd/
>     Everything works fine but when I do:
>     "/ldd mapserv/" it says:
>     /libproj.so.0 => /usr/lib/libproj.so.0 (0xb7504000)/
>     /libgdal.so.1 => not found/
>     /libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0xb74ec000)/
>     /libpq.so.5 => /usr/lib/libpq.so.5/
>     Why these libraries don't use the path specified in the configure
>     command. it'd be make senses to me if ldd output looks like:
>     /libproj.so.0 => /usr/local/gis/proj-4.7.0/lib/libproj.so.0
>     (0xb7504000)/
>     /libgeos_c.so.1 =>
>     ///usr/local/gis/geos-3.2.2///lib/libgeos_c.so.1 (0xb74ec000)/
>     What's wrong here?
>     Am I forced to do symbol links or set the custom libraries in LD_PATH?
>     Thanks!
>     Alberto Asuero
>     654 190 888 <tel:654%20190%20888>
>     Rodio 35
>     41007 Sevilla
>     Spain
>     T +34  954 437 818 <tel:%2B34%C2%A0%C2%A0954%20437%20818>
>     F +34  955 110 441 <tel:%2B34%C2%A0%C2%A0955%20110%20441>
>     Visita nuestra web
>     *www.gstgis.com*
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121116/e252657d/attachment.html>
