[mapserver-users] How can I avoid long notation of double values in label or info template for shapes?
Astrid Emde
astrid.emde at wheregroup.com
Fri Nov 23 02:04:08 PST 2012
Am 23.11.2012 10:39, schrieb Lars Lingner:
> On 23.11.2012 10:12, Astrid Emde wrote:
>> Hello,
>> I have a shapefile with a column of type double that contains values
>> like 2.54 or -2.03.
>> When I label the geometrie with this column or display this column in
>> my infotemplate I get the following notation of the values:
>> 2.54000000000e+000 -2.03000000000e+000
>> If there a way to tell MapServer to display the "normal" notation of
>> the value? Or do I have to change the shape?
> You can define your own format by using
> CLASS
> TEXT (round[numbercolumn], 2)
> LABEL
> END
> END
> In RFC 64 [1] you'll find some informations.
> I'm pretty sure I used it for myself. But grepping through my current
> mapfiles say otherwise. So I can't give an working example.
> Lars
> [1] http://mapserver.org/development/rfc/ms-rfc-64.html
Hi Lars,
thanks for the information!
It works fine for the label.
Before I defined LABELITEM mycolumn and got the long notation:
2.54000000000e+000
with definition TEXT mycolumn the label looks fine (without using any
function): 2.54
Is there a solution for the query result too?
Astrid
