[mapserver-users] How can I avoid long notation of double values in label or info template for shapes?
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Sun Nov 25 17:54:54 PST 2012
For completeness in a template you can use the item tag, e.g.:
  [item name="foo" precision="2"]
There is also a commify option to make big numbers look nicer. (e.g. 2,123.23)
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Astrid Emde [astrid.emde at wheregroup.com]
Sent: Friday, November 23, 2012 4:04 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How can I avoid long notation of double values in label or info template for shapes?
Am 23.11.2012 10:39, schrieb Lars Lingner:
> On 23.11.2012 10:12, Astrid Emde wrote:
>> Hello,
>> I have a shapefile with a column of type double that contains values
>> like 2.54 or -2.03.
>> When I label the geometrie with this column or display this column in
>> my infotemplate I get the following notation of the values:
>> 2.54000000000e+000 -2.03000000000e+000
>> If there a way to tell MapServer to display the "normal" notation of
>> the value? Or do I have to change the shape?
> You can define your own format by using
> CLASS
>   TEXT (round[numbercolumn], 2)
>   LABEL
>   END
> END
> In RFC 64 [1] you'll find some informations.
> I'm pretty sure I used it for myself. But grepping through my current
> mapfiles say otherwise. So I can't give an working example.
> Lars
> [1] http://mapserver.org/development/rfc/ms-rfc-64.html
Hi Lars,
thanks for the information!
It works fine for the label.
Before I defined LABELITEM mycolumn and got  the long notation:
2.54000000000e+000
with definition TEXT mycolumn the label looks fine (without using any
function): 2.54
Is there a solution for the query result too?
Astrid
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
