[mapserver-users] OGC spatial filter + SLD
Julien Cigar
jcigar at ulb.ac.be
Mon Nov 26 07:01:00 PST 2012
On 11/24/2012 14:23, Julien Cigar wrote:
> On 11/23/2012 19:12, Thomas Gratier wrote:
>> Hello,
> Hello,
>> Don't know exactly your case but you can maybe rely on runtime
>> substitution http://mapserver.org/cgi/runsub.html and spatial
>> abilities of your database e.g
>> http://postgis.refractions.net/docs/ST_Within.html
>> or on filter (support within
>> http://mapserver.org/mapfile/expressions.html#spatial-expressions-that-return-a-logical-value-geos
>> ) + runtime substitution
>> In all case, a bit dirty compare to SLD filter but no choice it seems.
> I'm slowly progressing on this issue:
> - I can confirm that Mapserver supports OGC spatial filters to filter
> WMS requests (so far I've tested with <ogc:BBOX> and <ogc:Within>. The
> filter is converted to an EXPRESSION clause in the Mapfile by Mapserver
> for example: EXPRESSION ([shape] within fromText('POLYGON
> ((24.2073126960992191 0.7680569582964826, 24.2968673039010241
> 0.7680569582964826, 24.2968673039010241 0.8576025453261950,
> 24.2073126960992191 0.8576025453261950, 24.2073126960992191
> 0.7680569582964826))'))
> - it seems that there is an obscure bug in the parsing code for the
> <gml:coordinates> tag:
> The following works:
> <ogc:BBOX>
> <ogc:PropertyName>geom</ogc:PropertyName>
> <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
> <gml:coordinates decimal="." cs="," ts=" ">24.207313,0.768057
> 24.296867,0.857603</gml:coordinates>
> </gml:Box>
> </ogc:BBOX>
> BUT, if there is a space (or a newline) in the <gml:coordinates
> decimal="." cs="," ts=" "> content it doesn't work, so the followings
> don't work:
> <gml:coordinates decimal="." cs="," ts=" "> 24.207313,0.768057
> 24.296867,0.857603 </gml:coordinates>
> 24.207313,0.768057 24.296867,0.857603
> </gml:coordinates>
> HOWEVER, this problem doesn't appear in an <ogc:Within>, in any case
> the <gml:coordinates> is parsed correctly:
> So the following works:
> <ogc:Within>
> <gml:Polygon srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
> <gml:outerBoundaryIs>
> <gml:LinearRing>
> 24.20731269609922 0.7680569582964826,24.296867303901024
> 0.857602545326195,24.20731269609922
> 0.857602545326195,24.20731269609922 0.7680569582964826
> </gml:coordinates>
> </gml:LinearRing>
> </gml:outerBoundaryIs>
> </gml:Polygon>
> </ogc:Within>
> For readability I've pasted the code on http://pastie.org/5427465
> Could someone confirm this is a bug .. ?
Another problem now: it seems impossible to combine a spatial filter
with a non-spatial filter (filters are simply ignored)
Any idea ..? My SLD file is here: http://pastie.org/5437516 and I've
tried with GML2 and GML3
Julien
>> Regards
>> ThomasG
> Regards,
> Julien
> mapserver-users at lists.osgeo.org
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121126/050c96ab/attachment.vcf>
