[mapserver-users] Problem with attribute query, multiple attributes
Bistrais, Bob
Bob.Bistrais at maine.gov
Thu Nov 29 06:44:59 PST 2012
Thanks Jeff. That link shows how to build an index on a shapefile. Is there an equivalent for File GDB? I'm looking at the GDAL document for GDB now, not seeing an index description.
-----Original Message-----
From: Jeff McKenna [mailto:jmckenna at gatewaygeomatics.com]
Sent: Wednesday, November 28, 2012 6:41 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problem with attribute query, multiple attributes
On 12-11-28 5:43 PM, Bistrais, Bob wrote:
> I am trying to set up an attribute query for a large parcel dataset
> (about 550,000 polygons). I am having trouble with the query
> exceeding the 30 second limit.
> I am trying to query on the map_bk_lot and town attributes. I can
> query on either one separately and get results, but I need to query on
> both at the same time.
> Here is my query expression:
> $queryExp = "('[TOWN]' == '007-042') AND ('[TOWN]' == 'Acton'))";
> ---Hardcoded for testing now, will eventually use variables
> $pLayer->queryByAttributes("MAP_BK_LOT",$queryExp,MS_SINGLE);
> ----Query statement
> The data is in an ESRI File GDB. I am using MS4w 3.0.4m MapServer
> 6.0.2, MapScript 6.1 for PHP
> One other thing worth mentioning- if I use a small subset of features
> (such as a town), the query will work without timing out. But I'm no
> longer convinced that dataset size is the problem since it will query
> on one attribute.
> Any ideas what's going wrong here?
A tip that might come in handy someday, if not in this case, could be to create an "attribute index" on your vector field (see example in http://www.gdal.org/ogr/drv_shapefile.html); I've done this before and it's improved attribute queries in MapServer significantly. You can generate one through an ogrinfo command with the "sql" switch.
Sorry I cannot provide exact FileGDB examples at the moment.
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
