[mapserver-users] Dimension default doesn't work and documentation is patchy
Stefan Schantz
SSchantz at BfS.de
Fri Nov 30 02:09:03 PST 2012
Hello everybody,
I have setup a mapfile with 4 dimensions. As long as I have the
dimension parameters in the request, it works fine. But if the dimension
parameter are missing, the default parameters won't be used. What is
wrong with my mapfile?
mapfile:
METADATA
"wms_title" "DWD Prognose Luft"
"wms_abstract" "Darstellung der Ausbreitungsrechnung in der
Luft; Der Layer muss über die Variablen VID (Vorgangs-ID), MGR_ID
(Messgrößen-ID), RIE (relatives Intervallende) abgefragt werden,
ansonsten werden die Defaultwerte verwendet"
"wms_enable_request" "*"
INCLUDE "../../include/general/standard_extent_welt.map"
"wms_dimensionlist" "MGR_ID,RIE,VID"
"wms_MGR_ID_item" "MGR_ID"
"wms_MGR_ID_extent" "373, 870, 384"
"wms_MGR_ID_units" "none"
"wms_MGR_ID_default" "373"
"wms_RIE_item" "RIE"
"wms_RIE_extent" "0, 6, 18, 30, 42, 54, 66, 78"
"wms_RIE_units" "hour"
"wms_RIE_default" "18"
"wms_VID_item" "VID"
"wms_VID_extent" "10000000/9999999999"
"wms_VID_units" "none"
"wms_VID_default" "984092599"
"wms_timeitem" "TIME"
"wms_timeextent" "2012-01-01 00:00/2012-12-31 00:00"
"wms_timedefault" "2012-03-12 00:00"
"default_MGR_ID" "373"
"default_RIE" "18"
"default_VID" "984092599"
END
By the way I think, there is a documentation error:
In the documentation http://mapserver.org/ogc/wms_dimension.html under
"Setting Up a WMS Layer with dimension support" the parameter
"wms_[dimensionname]_units" is also mandatory, otherwise I didn't get it
work.
Best regards,
Stefan
