[mapserver-users] Image 24bits
Brent Fraser bfraser at geoanalytic.com
Fri Nov 30 07:36:09 PST 2012
After looking into the Mapserver code, the answer is simply "Classifying
a 24 bit image is not currently supported in Mapserver".
Perhaps the doc
(http://mapserver.org/input/raster.html#how-are-rasters-added-to-a-map-file)
could be a little clearer.  Mapserver supports raster variables of
[red], [green],and [blue] in a CLASS EXPRESSION, but these work only on
the color values of palette of an 8-bit paletted image. Classifying a 24
bit image is not supported.
Other than performance (and since each pixel would have to be put
through the CLASS filters, it would be nasty), there's no reason I can
see not to classify a 24 bit (or higher?) image; somebody just needs to
write the code... :)
Best Regards,
Brent Fraser
On 11/28/2012 8:41 AM, Brent Fraser wrote:
> As I mentioned in the MS4W list, it sounds like a bug in Mapserver:
> WMS + Mapserver-with-CLASS + 24bit-raster-in-PostGIS = error
> You may want to show your mapfile here to get some feedback from
> others more experienced in using raster from PostGIS...
> Best Regards,
> Brent Fraser
> On 11/23/2012 10:07 AM, Saint wrote:
>> Dear all,
>> I'm attempting to classify images of 24 bits but I always have the error
>> saying this: ........Unable to access file. Attempt to classify 24bit
>> image,
>> this is unsupported.
>> My Mapfile is this one:
>> IMAGETYPE "png24"
>> OUTPUTFORMAT # Parameter Output
>>   NAME png24
>>   DRIVER "GD/PNG"
>>   MIMETYPE "image/png"
>>   EXTENSION PNG
>>   IMAGEMODE RGBA
>>   TRANSPARENT ON
>> END # end of parameter Output
>> and in the expression in the browser of GetMap is FORMAT=image/png
>> In the Layer description I have the special processing directives to
>> processed the 3 bands. But If put just 2 appear one empty image not the
>> error. I already read some documentation but I can't succeed.
>> any idea?
>> Many thanks and best regards,
>> José Santos
>> José Santos
>> GIS Analyst
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Image-24bits-tp5018436.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
