[mapserver-users] How do you display a symbol with two colours?
Havard Tveite
havard.tveite at umb.no
Wed Oct 10 00:30:07 PDT 2012
If you have moved to 6.2, you can consider using
ANCHORPOINT
http://mapserver.org/trunk/en/mapfile/symbol.html
On earlier verions you could try the approach suggested
in
http://mapserver.org/trunk/en/mapfile/symbology/construction.html#tricks
But that is kind of similar to what you have tried yourself.
To avoid gaps you could try this:
SYMBOL
NAME 'SQUARE_FULL'
TYPE vector
FILLED true
POINTS
0 0
0 1
1 1
1 0
0 0
END
END
SYMBOL
NAME 'SQUARE_R'
TYPE vector
FILLED true
POINTS
0.5 0
1 0
1 1
0.5 1
0.5 0
END
END
CLASS
STYLE
SYMBOL "SQUARE_FULL"
COLOR [LEFT_CLR]
SIZE 10
END
STYLE
SYMBOL "SQUARE_R"
COLOR [RIGHT_CLR]
SIZE 10
END
END
It seemed to work for me on 6.0.
Håvard
On 10/9/2012 10:32 PM, geographika wrote:
> Hi,
> I'm trying to draw a point layer, with each point represented in two colours (for example a square split in two with one half red and one half green).
> I can create the symbols and apply the data but either the squares are the incorrect shape, or they overlap. The closest I got was with the following CLASS definition, but then it appeared the colours were shown on the wrong side of the square.
> Images and further details at http://gis.stackexchange.com/questions/35283/mapserver-symbol-with-two-colours
> Symbol definitions:
> |SYMBOL
> NAME 'SQUARE_L'
> TYPE vector
> FILLED true
> POINTS
> 0 0
> 0 1
> 0.5 1
> 0.5 0
> 0 0
> END
> END
> SYMBOL
> NAME 'SQUARE_R'
> TYPE vector
> FILLED true
> POINTS
> 0.5 0
> 1 0
> 1 1
> 0.5 1
> 0.5 0
> END
> END
> # CLASS definition
> I'd like to symbolise a point dataset with a square (or circle) using two colours. This is useful for displaying values collected on both sides of a road (for example).
> split symbols
> I created two symbols, a left side and right side of the square as shown below:
> SYMBOL
> NAME 'SQUARE_L'
> TYPE vector
> FILLED true
> POINTS
> 0 0
> 0 1
> 0.5 1
> 0.5 0
> 0 0
> END
> END
> SYMBOL
> NAME 'SQUARE_R'
> TYPE vector
> FILLED true
> POINTS
> 0.5 0
> 1 0
> 1 1
> 0.5 1
> 0.5 0
> END
> END
> Then in my LAYER I can create a CLASS using the two different STYLES:
> CLASS
> STYLE
> SYMBOL"SQUARE_L"
> COLOR [LEFT_CLR]
> SIZE 10
> END
> STYLE
> SYMBOL"SQUARE_R"
> COLOR [RIGHT_CLR]
> SIZE 10
> END
> END
> Any help appreciated,
> Seth
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
