[mapserver-users] Still impossible to force labels inside their polygons?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Sep 4 07:16:40 PDT 2012
Is the short answer by Stephen Woodbridge "No" in the tread
http://osgeo-org.1560.n6.nabble.com/force-labels-to-fit-in-polygons-td4549296.html
still valid?
I have been trying to label a polygon dataset with Mapserver 6.2 beta2 and some labels keep on falling outside their polygons. By the way, the thread contains an advice that does not work for me:
" By the way, PROCESSING "LABEL_NO_CLIP=ON" will fix the label point at the polygon center.
-SteveW "
Is the solution to create a new layer with point-on-surface function and label then this point layer?
-Jukka Rahkonen-
