[mapserver-users] Still impossible to force labels inside their polygons?
Mark Volz
MarkVolz at co.lyon.mn.us
Tue Sep 4 11:15:40 PDT 2012
Hello,
I think many users would be able to take advantage of being able to force labels inside polygons. At the same time I realize that the current "bounding box" algorithm is fast. My question is could both be possible?
Scenario One: It would be fastest to use a bounding box to creating labels for a polygon that has a rectangular shape such as a section or township.
LABEL
MINFEATURESIZE AUTO
END
Scenario Two: Force labels to fit inside a polygon to avoiding ambiguity is more important than speed, such as a soils layer. A ForceLabelInside (or a better keyword) will tell Mapserver to use a slower algorithm to help place the label inside the polygon. This slower, but better placed algorithm might also be used for layers that are cached.
LABEL
MINFEATURESIZE AUTO
ForceLabeInside YES # Possibilities NO (current and default), YES (force label inside), ?
END
Thanks
Mark Volz
GIS Specialist
> It's tough to know what I'm looking at from the picture. What does the layer
> definition look like?
> At the moment polygon label point computation tries a couple of approaches
> get a label point inside the polygon: 1) compute a center of gravity 2) if that
> computation doesn't work (e.g. point is too close to the edge) then a
> scanline-based process is used to sample possible positions. The mid-point of
> the longest y sample is used.
> It's always trade-off with speed and the above seems a happy medium.
> Steve
