[mapserver-users] Fw: mapserver binary for CentOS?
Saka Royban
sakaroyban at yahoo.com
Thu Sep 6 00:39:19 PDT 2012
So, if i want not install anything on the server, i have to switch to a windows sever, i.e. IIS.
In IIS, i think there is a need to just copy mapserv.exe and some dlls. Am i right?
To: mapserver-users at lists.osgeo.org
Sent: Wednesday, September 5, 2012 11:01 PM
Subject: Re: [mapserver-users] Fw: mapserver binary for CentOS?
On CentOS there is no dll's those are windows only,
I'm not sure, just extracting the mapserv from the RPM is going to
work??
you need everything else (gdal, geos, etc)
without root or sh access, I don't see how you can run or install
mapserv
-Jeff Lake
MichiganWxSystem.com
AllisonHouse.com
TheWeatherCenter.net
GRLevelXStuff.com
On 9/5/2012 14:24, Saka Royban wrote:
Thanks a world for your helpful answer
>I wasn't aware that rpm could be extracted.
>Anyhow, in the link provided, i.e. http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm, i can get a 11 kb file when i download above-mentioned link. It seems there is no mapsrev file in it.
>Could you guide me where can i find the whole package?
>Also, just mapserv is sufficient to run a simple web mapping application? no other dll?
>Thanks in advance
> From: Peter Hopfgartner <peter.hopfgartner at r3-gis.com>
>Sent: Wednesday, September 5, 2012 6:05 PM
>Extracting the executable file "mapserv" from one of the above mentioned rpms and placing it in cgi-bin should give you a working MapServer CGI installation.
>Peter
>On 09/04/2012 04:20 PM, Saka Royban wrote:
>>----- Forwarded Message -----
>>From: Saka Royban <sakaroyban at yahoo.com>
>>To: Prabu Raja <prab.raja at gmail.com>
>>Sent: Tuesday, September 4, 2012 6:49 PM
>>Subject: Re: [mapserver-users] mapserver binary for CentOS?
>>Thanks for your help
>>I contacted host admin and he told
me they don't allow ssh access
because their host is of shared (!)
one. I was thinking maybe there is a
way to just copy the files into
cgi-bin folder, as it is for
mapserv.exe and its dependencies
(dlls) in MS4W package.
>>However, it seems if i want to use
MapServer in CGI mode i have to use
a Windows server. Otherwise, i must
switch to MapScript which is not
recommended for all applications.
>>If there is a way to use CGI
Mapserver in this case, please
inform me.
>>Regards
>> From: Prabu Raja <prab.raja at gmail.com>
>>To: Peter Hopfgartner <peter.hopfgartner at r3-gis.com>
>>Cc: mapserver-users at lists.osgeo.org
>>Sent: Tuesday, September 4, 2012 12:12 PM
>>Find below the steps, which I followed to install mapserver on CentOS 6 64 bit
>>sudo rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
>>yum install mapserver
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/cfitsio-3.240-3.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/fribidi-0.19.2-2.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/libdap-3.11.0-1.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/fcgi-2.4.0-10.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/librx-1.5-14.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/libspatialite-2.4.0-0.6.RC4.el6.x86_64.rpm
>>sudo rpm -Uvh http://mirror.centos.org/centos/6/os/x86_64/Packages/libgfortran-4.4.6-4.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/hdf5-1.8.5.patch1-7.el6.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/netcdf-4.1.1-3.el6.2.x86_64.rpm
>>sudo rpm -Uvh http://mirror.centos.org/centos/6/os/x86_64/Packages/expat-2.0.1-11.el6_2.x86_64.rpm
>>sudo rpm -Uvh http://dl.fedoraproject.org/pub/epel/6/x86_64/ogdi-3.2.0-0.14.beta2.el6.x86_64.rpm
>>cp /usr/libexec/mapserv
/var/www/cgi-bin/
>>On Tue, Sep 4, 2012 at 12:47 PM, Peter Hopfgartner <peter.hopfgartner at r3-gis.com> wrote:
>>On 09/04/2012 08:33 AM, Saka Royban wrote:
>>>Hi guys
>>>>I'm a newbie to mapserver and i've been using MS4W for a while. Now, i'm gonna use MapServer CGI in my website. So, I asked my host admin of the version of Linux and he replied me that CentOS is running on the server.
>>>>Searching internet, unfortunately, i didn't find mapserver binary for CentOS. I just found some instructions for building mapserver in Linux but i'm a windows follower and hence, not familiar with Linux.
>>>>My host provider supports CGI applications. How can i get a binary MapServer compatible with Centos?
>>>>Best Regards
>>>>_______________________________________________
mapserver-users mailing list mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
You'll find some GIS packages here: http://elgis.argeo.org/
Peter Hopfgartner
web : http://www.r3-gis.com
list
>>Regards,
>>Prabu Raja
Peter Hopfgartner
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120906/cf262400/attachment-0001.html>
