[mapserver-users] TinyOWS 0.9 Problem in windows 7
Budi Hermansyah
boedy1996 at gmail.com
Thu Sep 6 04:23:38 PDT 2012
Thank you Rahkonen, It's work. One more question. Do you think will be
there is another problem using TinyOWS+Mapfile and openlayers for editing
Bests,
BH
On Thu, Sep 6, 2012 at 1:53 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,****
> There is a newer version than 0.9 available at****
> http://maptools.org/ms4w/index.phtml?page=downloads.html****
> I recommend to update. However, I am remembering that there were some
> problems with the Windows version.****
> When it comes to your problem, there must be something wrong with your
> data but it is hard to say directly what it is. I suggest to read****
> http://mapserver.org/trunk/tinyows/openlayershowtobasic.html****
> use the same France dataset and adapt the instructions to suit Windows.
> Then you can do the first tests with the France-dataset. When your server
> is OK with the demo data you can continue to add your own data into the
> service.****
> These excerpts show that WFS does not find any data from your database ***
> GetCapabilities:****
> <FeatureType>****
> <Name>tows:wfst_test</Name>****
> <Title>wfst_test</Title>****
> <SRS/>****
> <LatLongBoundingBox minx="0" miny="0" maxx="0" maxy="0"/>****
> </FeatureType>****
> Note: No coordinate system and zero bounding box****
> GetFeature:****
> It is just empty. It still gets the bounding box somewhere so the table
> exists. Are you sure that your table in not empty?****
> -Jukka Rahkonen-****
> Budi Hermansyah wrote:****
> Hi Rahkonen,****
> all the url seems work shown below. Please let me know ...****
> Thks****
> http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&version=1.0.0&request=GetCapabilities
> <WFS_Capabilities version="1.0.0" updateSequence="0" xsi:schemaLocation="
> http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd"><Service><Name>TinyOWS
> ServerWFS</Name><Title>TinyOWS Server-Demo Service</Title><OnlineResource>
> http://127.0.0.1/cgi-bin/tinyows.exe</OnlineResource></Service><Capability><Request><GetCapabilities><DCPType><HTTP><Get
> onlineResource="http://127.0.0.1/cgi-bin/tinyows.exe?"/></HTTP></DCPType><DCPType><HTTP><Post
> onlineResource="http://127.0.0.1/cgi-bin/tinyows.exe"/></HTTP></DCPType></GetCapabilities><DescribeFeatureType><SchemaDescriptionLanguage><XMLSCHEMA/></SchemaDescriptionLanguage><DCPType><HTTP><Get
> onlineResource="http://127.0.0.1/cgi-bin/tinyows.exe"/></HTTP></DCPType></DescribeFeatureType><GetFeature><ResultFormat><GML2/></ResultFormat><DCPType><HTTP><Get
> onlineResource="http://127.0.0.1/cgi-bin/tinyows.exe"/></HTTP></DCPType></GetFeature><Transaction><DCPType><HTTP><Get
> onlineResource="http://127.0.0.1/cgi-bin/tinyows.exe"/></HTTP></DCPType></Transaction></Request></Capability><FeatureTypeList><Operations><Query/></Operations><FeatureType><Name>tows:wfst_test</Name><Title>wfst_test</Title><SRS/><LatLongBoundingBox
> maxy="0"/></FeatureType></FeatureTypeList><ogc:Filter_Capabilities><ogc:Spatial_Capabilities><ogc:Spatial_Operators><ogc:Disjoint/><ogc:Equals/><ogc:DWithin/><ogc:Beyond/><ogc:Intersect/><ogc:Touches/><ogc:Crosses/><ogc:Within/><ogc:Contains/><ogc:Overlaps/><ogc:BBOX/></ogc:Spatial_Operators></ogc:Spatial_Capabilities><ogc:Scalar_Capabilities><ogc:Logical_Operators/><ogc:Comparison_Operators><ogc:Simple_Comparisons/><ogc:Between/><ogc:Like/><ogc:NullCheck/></ogc:Comparison_Operators><ogc:Arithmetic_Operators><ogc:Simple_Arithmetic/><ogc:Functions><ogc:Function_Names><ogc:Function_Name
> nArgs="1">abs</ogc:Function_Name><ogc:Function_Name
> nArgs="1">acos</ogc:Function_Name><ogc:Function_Name
> nArgs="1">asin</ogc:Function_Name><ogc:Function_Name
> nArgs="1">atan</ogc:Function_Name><ogc:Function_Name
> nArgs="1">avg</ogc:Function_Name><ogc:Function_Name
> nArgs="1">cbrt</ogc:Function_Name><ogc:Function_Name
> nArgs="1">ceil</ogc:Function_Name><ogc:Function_Name
> nArgs="1">ceiling</ogc:Function_Name><ogc:Function_Name
> nArgs="1">cos</ogc:Function_Name><ogc:Function_Name
> nArgs="1">cot</ogc:Function_Name><ogc:Function_Name
> nArgs="1">count</ogc:Function_Name><ogc:Function_Name
> nArgs="1">degrees</ogc:Function_Name><ogc:Function_Name
> nArgs="1">exp</ogc:Function_Name><ogc:Function_Name
> nArgs="1">floor</ogc:Function_Name><ogc:Function_Name
> nArgs="1">length</ogc:Function_Name><ogc:Function_Name
> nArgs="1">ln</ogc:Function_Name><ogc:Function_Name
> nArgs="1">log</ogc:Function_Name><ogc:Function_Name
> nArgs="1">min</ogc:Function_Name><ogc:Function_Name
> nArgs="1">max</ogc:Function_Name><ogc:Function_Name
> nArgs="1">radians</ogc:Function_Name><ogc:Function_Name
> nArgs="1">round</ogc:Function_Name><ogc:Function_Name
> nArgs="1">sin</ogc:Function_Name><ogc:Function_Name
> nArgs="1">sqrt</ogc:Function_Name><ogc:Function_Name
> nArgs="1">tan</ogc:Function_Name><ogc:Function_Name
> nArgs="1">trunc</ogc:Function_Name></ogc:Function_Names></ogc:Functions></ogc:Arithmetic_Operators></ogc:Scalar_Capabilities></ogc:Filter_Capabilities></WFS_Capabilities>
> http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&version=1.0.0&request=DescribeFeatureType&Typename=tows:wfst_test
> <xs:schema targetNamespace="http://www.tinyows.org"
> elementFormDefault="qualified" version="1.0"><xs:import namespace="
> http://www.opengis.net/gml" schemaLocation="
> http://schemas.opengis.net/gml/2.1.2/feature.xsd"/><xs:element
> name="wfst_test" type="tows:wfst_testType"
> substitutionGroup="gml:_Feature"/><xs:complexType
> name="wfst_testType"><xs:complexContent><xs:extension
> base="gml:AbstractFeatureType"><xs:sequence><xs:element name="fid"
> type="double" minOccurs="0" maxOccurs="1"/><xs:element name="the_geom"
> type="gml:GeometryPropertyType" minOccurs="0"
> maxOccurs="1"/></xs:sequence></xs:extension></xs:complexContent></xs:complexType></xs:schema>
> http://127.0.0.1/cgi-bin/tinyows.exe?service=WFS&version=1.0.0&request=GetFeature&Typename=tows:wfst_test&maxFeatures=2
> <wfs:FeatureCollection xsi:schemaLocation="http://www.tinyows.org
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://schemas.opengis.net/gml/2.1.2/feature.xsd"><gml:boundedBy><gml:Box
> srsName="EPSG:-1"><gml:coordinates decimal="." cs="," ts="
> ">491007.937500,5458904.500000
> 491243.000000,5459214.000000</gml:coordinates></gml:Box></gml:boundedBy></wfs:FeatureCollection>
> On Thu, Sep 6, 2012 at 1:23 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> wrote:****
> Hi,****
> Do not use OpenLayers for testing, use something that you can control.
> What do you get back if you send these basic WFS requests with a browser:
> DescribeFeatureType&Typename=tows:wfst_test****
> GetFeature&Typename=tows:wfst_test&maxFeatures=2****
> Hi Guys,****
> I try to use tinyOWS. when Openlayers called the service the result are :*
> <wfs:FeatureCollection xmlns:tows="http://www.tinyows.org" xmlns:wfs="
> http://www.opengis.net/wfs" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="
> http://www.opengis.net/gml" xmlns:xsd="http://www.w3.org/2001/XMLSchema
> " xmlns:ogc="http://www.opengis.net/ogc" xmlns:xlink="
> http://www.w3.org/1999/xlink" xmlns:ows="http://www.opengis.net/ows
> " xsi:schemaLocation="http://www.tinyows.org
> http://schemas.opengis.net/gml/2.1.2/feature.xsd">****
> <gml:boundedBy>****
> <gml:Box srsName="EPSG:-1">****
> <gml:coordinates decimal="." cs="," ts=" ">-1.#INF00,-1.#INF00
> 1.#INF00,1.#INF00</gml:coordinates>****
> </gml:Box>****
> </gml:boundedBy>****
> </wfs:FeatureCollection>****
> Can anyone please help me and tell what's going on??****
> Bests,****
> BH****
> mapserver-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-users****
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120906/cb38c61d/attachment-0001.html>
