[mapserver-users] [Python+MapScript] Convert imageObj to PIL Image
thomas bonfort
thomas.bonfort at gmail.com
Fri Sep 7 06:49:54 PDT 2012
IIRC, PIL does not support 8bit pngs with transparency, so writing it
to a file won't help. If you need alpha, you'll have to stick with
32bit pngs.
thomas
On Fri, Sep 7, 2012 at 3:35 PM, Jelmer Baas <baas at speerit.nl> wrote:
> Hi All,
> I've been testing today in Python, trying to get a MapScript imageObj into an python Image object. This works via the following code:
> map.transparent = MS_ON
> map.selectOutputFormat('png8')
> map.outputformat.imagemode = MS_IMAGEMODE_RGBA
> map.outputformat.transparent = MS_ON
> img = map.draw()
> mem_png = StringIO.StringIO(img.saveToString())
> _img = Image.open(mem_png)
> However, the _img file lost its transparency, even though it's still (or again) PNG. There MUST be a better way of getting the PNG file into PIL, right? Something besides writing it to a tempfile, opening it, and deleting it?
> On a side note, I only use this rendered image temporarily, I only need to cut it up in smaller bits and return those to my client. So if there's some sort of format that supports transparcency but without the PNG compression overhead, that would be even better!
> Regards,
> Jelmer Baas
> mapserver-users at lists.osgeo.org
