[mapserver-users] MODE=legendicon & GROUP Layers
Andrew Cowie
CowieA at landcareresearch.co.nz
Sat Sep 8 01:13:00 PDT 2012
Certainly our mapfiles stay fairly static once we've set them up. Thanks for the suggestion, will have a look at trying it out.
Cheers
Andrew
From: <Basques>, "Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>>
Date: Friday, 7 September 2012 17:06
To: Andrew Cowie <cowiea at landcareresearch.co.nz<mailto:cowiea at landcareresearch.co.nz>>, "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: RE: MODE=legendicon & GROUP Layers
All,
I’ve gotten around this in the past by using dummy layers specifically for Legend Creation. You have complete control over the legend this way and can mix and match data sources however is required without needing to actually map the data out. It is more work overall, but if your MapFiles don’t change often, it’s usually a one time setup thing.
I have a few map layers that have 7 or 8 different thresholds for display set MIN/MAXSCALEDENOMs and they all get a dummy layer that displays the same thing for all thresholds.
Bobb
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrew Cowie
Sent: Friday, September 07, 2012 10:46 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] MODE=legendicon & GROUP Layers
Hello list
Wondering if anyone can help…
We have been utilising the legendicon mode to create a custom legend in our application, however some recent work to try and speed up our WMS has reworked our mapfiles slightly, making use of GROUP LAYERs to group almost identical LAYERs together, the only difference in the LAYERs being MAX & MINSCALEDENOM and the DATA request string to our PostGIS database – hitting a generalised version of the geometry at smaller scales.
LAYER
NAME 'lri_luc_main_gen_500k'
GROUP 'lri_luc_main'
DATA 'the_geom_gen_500k FROM "data"."lri" USING UNIQUE gid USING srid=2193'
INCLUDE 'includes/lri_luc_main_layer.inc'
MINSCALEDENOM 251001
END
LAYER
NAME 'lri_luc_main_full'
DATA 'the_geom FROM "data"."lri" USING UNIQUE gid USING srid=2193'
MAXSCALEDENOM 251000
MINSCALEDENOM 15000
END
The request for the legend icon is of the form:
http://<servername>/cgi-bin/mapserv.fcgi?FORMAT=image/gif&MAP=lri.map&MODE=legendicon&ICON=lri_luc_main,1<http://%3cservername%3e/cgi-bin/mapserv.fcgi?FORMAT=image/gif&MAP=lri.map&MODE=legendicon&ICON=lri_luc_main,1>
This worked fine before we started using GROUPs, however now we now encounter the error:
mapserv(): Web application error. Icon layer=lri_luc_main not found in map file.
Does the legendicon mode work with GROUP layers?
If not, is there a way round this?
Or alternatively, perhaps there is a better way to request a generalised version of the geometry that doesn't involve GROUP LAYERs?
Any help or suggestions much appreciated.
Many thanks
Andrew
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120908/57a78b13/attachment.html>
