[mapserver-users] PostGIS geography layer doesn't render in Mapserver
Raj Singh
rsingh at opengeospatial.org
Thu Sep 13 10:01:41 PDT 2012
I believe my problem is similar to this:
http://osgeo-org.1560.n6.nabble.com/Cannot-get-a-PostGIS-layer-to-render-in-Mapserver-td4233163.html
But that post is from 2010 and surprisingly I can't find anything newer with this issue.
I want Mapserver to serve data in PostGIS 1.5.3 that has a geography point column (NOT geometry!).
I'm using leaflet and trying to display a WMS layer out of mapserver on top of cloudmade tiles. When I make the query, mapserver debugging output gives me the following. Help!
[Thu Sep 13 11:45:55 2012].55933 msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR: function st_force_2d(geography) does not exist
LINE 1: select encode(ST_AsBinary(ST_Force_2D("geogpt"),'NDR'),'hex'...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
Here is how the layer is defined in the .map file (p.s. if I use a geometry column everything works fine)
LAYER
NAME mylayer
METADATA
"wms_title" "mywms"
"wms_enable_request" "*"
"gml_include_items" "all"
END
TYPE POINT
PROJECTION
"init=epsg:4326"
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=mydb user=myuser password=mypw"
DATA "geogpt from mytable using srid=4326 using unique oid"
Raj
