[mapserver-users] [TinyOWS] Broken config using a MAPFILE?
Richard Turner
richard.turner at mediatelgroup.co.uk
Wed Sep 19 02:16:45 PDT 2012
On Wed, 2012-09-19 at 09:09 +0000, Rahkonen Jukka wrote:
> At least you will have some troubles with your extents which do not
> match with your output projection
> EXTENT -180 -90 180 90
> UNITS DD
Thanks for pointing-out that; I'll fix it.
> This may or may not be the reason for the failure but correct it
> anyway to use meters and the extents of your data.
> I can also see that your Box is not a box but it is a line because the
> easting coordinates are the same
> 417651.92249206,6609322.2049643
> 417651.92249206,6811115.9596091
Nope, the coordinates are (note the negative number):
-417651.92249206,6609322.2049643 : 417651.92249206,6811115.9596091.
It's OpenLayers that's generating the request automatically for me, so I
have little control over that. Besides, that request works fine if I
switch to using MapServer instead of TinyOWS, so I think it must be a
configuration issue for TinyOWS. Hopefully it's the extents
misconfiguration...
Cheers,
R
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120919/034e2f55/attachment.html>
