[mapserver-users] some questions regarding getFeatureInfo, SLD, PostGIS
Julien Cigar
jcigar at ulb.ac.be
Fri Sep 21 03:24:43 PDT 2012
Hello,
I'm using Mapserver 6.0.1 with the following PostGIS layer:
http://pastie.org/private/84042k84vmljbontls5xvq
The user has the possibility to select quite a lot of filters, which
implies that the SQL query should, in theory ,be generated dynamically.
As this is not possible with Mapserver (run-time substitution with HTTP
parameters and VALIDATION ... END isn't powerful enough is my case), I'm
dynamically generating an SLD
(http://pastie.org/private/p66ml3uvqwcnphuuvera) to filter items and it
works very well.
Some questions:
- Why does Mapserver doesn't have a very lightweight template language
(or something similar) to dynamically build a string following given
parameters? It could be really useful to avoid unnecessary JOIN, etc.
For example something like:
http://pastie.org/private/bojm3pi1dwrv18m2tvq (this is just an example,
but the idea is there)
- I noticed in the PostgreSQL logs that sometimes Mapserver adds an
additional condition to the WHERE clause when SLD is used. For example
with the following <ogc:Filter> in my SLD:
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>basis_of_record_id</ogc:PropertyName>
<ogc:Literal>1</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
Mapserver adds an additional "and (( ("basis_of_record_id"= 1) ))":
(...) AS q where geom && GeomFromText('POLYGON((-3.6860351557368
-9.81732918571448,-3.6860351557368 9.81732918571447,47.6860351496117
9.81732918571447,47.6860351496117 -9.81732918571448,-3.6860351557368
-9.81732918571448))',4326) and (( ("basis_of_record_id"= 1) ))
which is not bad as less rows have to be post-processed by the SLD engine.
However, as soon as I add an additional <ogc:or> (or <ogc:and>) as:
<ogc:or>
<ogc:Literal>2</ogc:Literal>
</ogc:or>
Mapserver doesn't add this additional AND/OR clause (and ((
("basis_of_record_id"= 1) OR ("basis_of_record_id" = 2) )) in this
case).. Why ?
- Is it normal that my SLD is totally ignored when I'm using
REQUEST=GetFeatureInfo? Is the SLD only processed with REQUEST=GetMap?
If this is the case, what's the typical alternative way of doing it?
Should I go through WFS .. ?
In advance, thank you for your answers :)
Julien
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120921/349b1c33/attachment.vcf>
