[mapserver-users] some questions regarding getFeatureInfo, SLD, PostGIS
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Fri Sep 21 04:24:45 PDT 2012
At the SQL level, you can do some fancy work with CASE and setting some
default values
The CASE function allows you to set all kind of logical comparisons. You
can do conditional joins that way, setting the join condition to a non
matching value when you don't want the join, etc. SQL is more powerful
than any template language.
Mike
On 9/21/12 7:07 AM, "Julien Cigar" <jcigar at ulb.ac.be> wrote:
>On 09/21/2012 12:50, Rahkonen Jukka wrote:
>> Hi,
>Hello,
>> So you have tried to define variables %SEX% and %BOD_ID%, used them
>>inside your DATA and then fired  WMS GetMaps by
>>adding&SEX=your_value&BOD_ID=your_id? Does in not work or why it is not
>>powerful enough?
>It is not powerful enough because it doesn't allow you to make simple
>logical tests (if defined/equals/...), the run-time substitution is a
>simple "replace %FOO%" by the value of FOO= from the query string.
>It doesn't allow you to do something like: "if FOO is defined or equal
>to xxx, then add "JOIN foo f ON f.id = bar.foo_id", select additional
>columns, and add a "WHERE foo.id = ..." at a certain place in the DATA
>string".
>I guess mapscript should be used in this case, but it would be really
>interesting to have this simple template language (or another solution)
>without having to involve mapscript.
>Julien
>> -Jukka Rahkonen-
>> Julien Cigar wrote:
>>> Hello,
>>> I'm using Mapserver 6.0.1 with the following PostGIS layer:
>>> http://pastie.org/private/84042k84vmljbontls5xvq
>>> The user has the possibility to select quite a lot of filters, which
>>>implies that
>>> the SQL query should, in theory ,be generated dynamically.
>>> As this is not possible with Mapserver (run-time substitution with HTTP
>>> parameters and VALIDATION ... END isn't powerful enough is my case),
>>>I'm
>>> dynamically generating an SLD
>>> (http://pastie.org/private/p66ml3uvqwcnphuuvera) to filter items and it
>>> works very well.
>>> Some questions:
>>> - Why does Mapserver doesn't have a very lightweight template language
>>>(or
>>> something similar) to dynamically build a string following given
>>>parameters? It
>>> could be really useful to avoid unnecessary JOIN, etc.
>>> For example something like:
>>> http://pastie.org/private/bojm3pi1dwrv18m2tvq (this is just an
>>>example, but
>>> the idea is there)
>>> - I noticed in the PostgreSQL logs that sometimes Mapserver adds an
>>> additional condition to the WHERE clause when SLD is used. For example
>>>with
>>> the following<ogc:Filter>  in my SLD:
>>> <ogc:Filter>
>>> <ogc:PropertyIsEqualTo>
>>> <ogc:PropertyName>basis_of_record_id</ogc:PropertyName>
>>> <ogc:Literal>1</ogc:Literal>
>>> </ogc:PropertyIsEqualTo>
>>> </ogc:Filter>
>>> Mapserver adds an additional "and (( ("basis_of_record_id"= 1) ))":
>>> (...) AS q where geom&&  GeomFromText('POLYGON((-3.6860351557368
>>> -9.81732918571448,-3.6860351557368 9.81732918571447,47.6860351496117
>>> 9.81732918571447,47.6860351496117 -9.81732918571448,-3.6860351557368
>>> -9.81732918571448))',4326) and (( ("basis_of_record_id"= 1) ))
>>> which is not bad as less rows have to be post-processed by the SLD
>>>engine.
>>> However, as soon as I add an additional<ogc:or>  (or<ogc:and>) as:
>>> <ogc:or>
>>> <ogc:Literal>2</ogc:Literal>
>>> </ogc:or>
>>> Mapserver doesn't add this additional AND/OR clause (and ((
>>> ("basis_of_record_id"= 1) OR ("basis_of_record_id" = 2) )) in this
>>>case).. Why
>>> - Is it normal that my SLD is totally ignored when I'm using
>>> REQUEST=GetFeatureInfo? Is the SLD only processed with
>>> REQUEST=GetMap?
>>> If this is the case, what's the typical alternative way of doing it?
>>> Should I go through WFS .. ?
>>> In advance, thank you for your answers :) Julien
>>> No trees were killed in the creation of this message.
>>> However, many electrons were terribly inconvenienced.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
