[mapserver-users] Fwd: mapcache module load error (in apache2)
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 21 06:45:17 PDT 2012
On 9/21/2012 5:12 AM, 李杨 wrote:
> I just test it in firefox browser
> IN the browser there are some missing img, point to url like this
> I use the "http://199.195.214.155/mapcache/demo/tms" to test,
> 199.195.214.155 is my server.
> http://199.195.214.155/mapcache/tms/1.0.0/osm@WGS84/1/3/1.png
> but as I know my mapcache is not in my www dir. so mapcache dir there is
> no file.
When I click on the png link I get:
wms request for tileset osm returned an unsupported format:
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
loadMap(): Web application error. CGI variable "map" is not set.
</BODY></HTML>
Also mapcache in the path is not a directory it is an application that
is running as an apache module, even those it looks like a directory. It
is working fine and as Thomas noted if you had clicked on the link you
would have seeen the error message above. You must have you mapcache.xml
file configured to point to a wms service named osm which is returning
an unsupported format.
Start looking there for your problem.
-Steve W
> I just configure the mapserver , mapcache like this site say:
> https://github.com/mapserver/mapserver/wiki/RenderingOsmDataOnUbuntuv2
> my mapcacche dir is in " /root/osm-demo/mapcache/cache"
> So I can not solve. I should refer to mapcache open doc?
> 2012/9/21 thomas bonfort <thomas.bonfort at gmail.com
> <mailto:thomas.bonfort at gmail.com>>
> If you've not accessed the tiles through a browser or manually
> launched a seeding, then it's normal for the cache dir to be empty.
> Navigate to http://localhost/mapcache/demo/tms to check.
> On Fri, Sep 21, 2012 at 10:16 AM, 李杨 <gisyangli at gmail.com
> <mailto:gisyangli at gmail.com>> wrote:
> > I have solve the problem using ldconfig.
> > But nwo I feel that the mapcache is not working( not take
> effect). I check
> > the cache dir and found nothing!
> > Any one help me?
> > ---------- Forwarded message ----------
> > From: 李杨 <gisyangli at gmail.com <mailto:gisyangli at gmail.com>>
> > Date: 2012/9/21
> > Subject: mapcache module load error (in apache2)
> > To: mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> > Hi, everyone.
> > I have a a problem when I use mapcache.
> > when I install the mapcache module into apache2 and restart apachae2,
> > I got the error like below, and I can not solve the problems.
> > root at VM322A:~/osm-demo/mapcache-git# sudo apache2ctl restart
> > apache2: Syntax error on line 208 of /etc/apache2/apache2.conf:
> Syntax error
> > on line 1 of /etc/apache2/mods-
> > enabled/mapcache.load: Cannot load
> /usr/lib/apache2/modules/mod_mapcache.so
> > into server: libmapcache.so.0: cannot
> > open shared object file: No such file or directory
> > Anyone could help?
> > Yang Li
> > GIS Developer
> > P.R.China
> > Yang Li
> > GIS Developer
> > P.R.China
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Yang Li
> GIS Developer
> P.R.China
