[mapserver-users] How to add marker on openlayers ?
Stephen Woodbridge woodbri at swoodbridge.com
Sun Sep 23 11:36:17 PDT 2012
Sorry but this is an OpenLayers question and needs to be asked on the
OpenLayers list.
On 9/22/2012 12:09 PM, 李杨 wrote:
> I before use a map,then I can add markers.   But when I use mapcache
> tile the map, then why can not show the markers
> the former js code like this:, the marker can show, and it is not a tile map .
> <!DOCTYPE html>
> <html>
>    <head>
>      <title>India Mapserver</title>
>      <script src="http://openlayers.org/api/OpenLayers.js"></script>
>      <script type="text/javascript">
>          var map,baseLayer;
> 	var lat;
>          var lng;
>          var pointslng = [];
>          var pointslat = [];
>          var objNodeList;
>          var Node;
>          var format;
>          var isChrome;
>    try //Internet Explorer
>    xdoc=new ActiveXObject("Microsoft.XMLDOM");
> catch(e)
>    try //Firefox, Mozilla, Opera, etc.
>      xdoc=document.implementation.createDocument("","",null);
>    catch(e) {alert(e.message)}
> try
>    xdoc.async=false;
>    xdoc.load("getDeviceInfo.php.xml");
> catch(e) {
> isChrome=true;
> xdoc = null;
> if(isChrome)
> var xmlhttp = new XMLHttpRequest();
> xmlhttp.open("GET","http://61.149.194.113/getDeviceInfo.php.xml",false);
> xmlhttp.send(null);
> xdoc = xmlhttp.responseXML;
>   nodes = xdoc.documentElement.childNodes;
>    objNodeList = xdoc.getElementsByTagName("marker");
>    for ( var i=0; i<objNodeList.length; i++)
> Node =objNodeList[i];
>    for (var k=0; k< Node.attributes.length; k++)
>       if(Node.attributes[k].nodeName == "lng")
>        lng = Node.attributes[k].nodeValue;
>       if(Node.attributes[k].nodeName == "lat")
>        lat = Node.attributes[k].nodeValue;
>    pointslng.push(  lng ) ;
>    pointslat.push(  lat ) ;
>      function init() {
>      // The overlay layer for our marker, with a simple diamond as symbol
>      var overlay = new OpenLayers.Layer.Vector('Overlay', {
>          styleMap: new OpenLayers.StyleMap({
>              externalGraphic: 'marker.png',
>              graphicWidth: 20, graphicHeight: 24, graphicYOffset: -24,
>              title: '${tooltip}'
>     for (var l=0; l< pointslng.length; l++)
>      // The location of our marker and popup. We usually think in geographic
>      // coordinates ('EPSG:4326'), but the map is projected ('EPSG:3857').
>      var myLocation = new OpenLayers.Geometry.Point( pointslng[l],pointslat[l])
>          .transform('EPSG:4326', 'EPSG:3857');
>      // We add the marker with a tooltip text to the overlay
>      overlay.addFeatures([
>          new OpenLayers.Feature.Vector(myLocation, {tooltip: 'OpenLayers'})
>      // A popup with some information about our location
>      var popup = new OpenLayers.Popup.FramedCloud("Popup",
>          myLocation.getBounds().getCenterLonLat(), null,
>          '<a target="_blank" href="http://openlayers.org/">We</a> ' +
>          'could be here.<br>Or elsewhere.', null,
>          true // <-- true if we want a close (X) button, false otherwise
>             map = new OpenLayers.Map({
> div:"map",projection:"EPSG:3857",
> layers:[ new OpenLayers.Layer.MapServer("OSM
> map","/cgi-bin/mapserv?",{map:"/root/osm-demo/basemaps/osm-google.map",layers:"all",map_image_type:"png"},{singleTile:true,ratio:1.0})],
> center:myLocation.getBounds().getCenterLonLat(),zoom:5});
> map.addLayer(overlay);
>      </script>
>      <style>
>      @media screen
>         #map{width: 800px; height:400px; border: 2px solid black;}
>      </style>
>    </head>
>    <body onload="init()">
>       <h3>India Mapserver</h3>
>       <div id="map"></div>
>     </body>
> </html>
> For reason fast the map show, I use mapcache,
> when i use the mapcache tile map.
> I just use the add-marker code before add  to this one:
> ______________________________________________________
> <html="http://www.w3.org/1999/xhtml">
>    <head>
>      <title>mod-mapcache demo service</title>
>      <style type="text/css">
>      #map {
>      width: 100%;
>      height: 100%;
>      border: 1px solid black;
>      </style>
>      <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
>          var map,baseLayer;
> 	var lat;
>          var lng;
>          var pointslng = [];
>          var pointslat = [];
>          var objNodeList;
>          var Node;
>          var format;
>          var isChrome;
>    catch(e)
> try
>    xdoc.async=false;
> catch(e) {
> isChrome=true;
> xdoc = null;
> if(isChrome)
> xmlhttp.send(null);
> function init(){
>      map = new OpenLayers.Map( 'map', {
>          displayProjection: new OpenLayers.Projection("EPSG:4326")
>      var osm_WGS84_tms_layer = new OpenLayers.Layer.TMS( "osm-WGS84-TMS",
>          "http://61.149.194.113/mapcache/tms/",
>          { layername: 'osm at WGS84', type: "png", serviceVersion:"1.0.0",
>            gutter:0,buffer:0,isBaseLayer:true,transitionEffect:'resize',
>            tileOrigin: new OpenLayers.LonLat(-180.000000,-90.000000),
>            resolutions:[0.70312500000000000000,0.35156250000000000000,0.17578125000000000000,0.08789062500000000000,0.04394531250000000000,0.02197265625000000000,0.01098632812500000000,0.00549316406250000000,0.00274658203125000000,0.00137329101562500000,0.00068664550781250000,0.00034332275390625000,0.00017166137695312500,0.00008583068847656250,0.00004291534423828120,0.00002145767211914060,0.00001072883605957030,0.00000536441802978516],
>            zoomOffset:0,
>            units:"dd",
>            maxExtent: new
> OpenLayers.Bounds(-180.000000,-90.000000,180.000000,90.000000),
>            projection: new OpenLayers.Projection("EPSG:4326".toUpperCase()),
>            sphericalMercator: false
>      map.addLayer(osm_WGS84_tms_layer)
>      var osm_g_tms_layer = new OpenLayers.Layer.TMS( "osm-g-TMS",
>          "http://199.195.214.155/mapcache/tms/",
>          { layername: 'osm at g', type: "png", serviceVersion:"1.0.0",
>            tileOrigin: new OpenLayers.LonLat(-20037508.342789,-20037508.342789),
>            resolutions:[156543.03392804099712520838,78271.51696402048401068896,39135.75848201022745342925,19567.87924100512100267224,9783.93962050256050133612,4891.96981025128025066806,2445.98490512564012533403,1222.99245256282006266702,611.49622628141003133351,305.74811314070478829308,152.87405657035250783338,76.43702828517623970583,38.21851414258812695834,19.10925707129405992646,9.55462853564703173959,4.77731426782351586979,2.38865713391175793490,1.19432856695587897633,0.59716428347793950593],
>            zoomOffset:0,
>            units:"m",
>            maxExtent: new
> OpenLayers.Bounds(-20037508.342789,-20037508.342789,20037508.342789,20037508.342789),
>            projection: new OpenLayers.Projection("EPSG:900913".toUpperCase()),
>            sphericalMercator: true
>      map.addLayer(osm_g_tms_layer)
>              title: '${tooltip}'
>      alert("m");
>      map.addLayers(overlay)
>      alert("asd");
>     if(!map.getCenter())
>       map.zoomToMaxExtent();
>      map.addControl(new OpenLayers.Control.LayerSwitcher());
>      map.addControl(new OpenLayers.Control.MousePosition());
>      </script>
>    </head>
>      <div id="map">
>      </div>
> </body>
> </html>
> the map load speed is very fast, but the marker disappear.
> The marker location info is in " latitude & longitute",
> I guess is the projection problem.
> Can anyone help me ?
