[mapserver-users] Label Annotation and repeatdistance
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 24 05:26:26 PDT 2012
REPEATDISTANCE only works with lines. What is does is to create multiple
label points along the line. This does not make sense for ANNOTATION
layers for two reasons:
1. annotation is a point, you can not repeat along a point
2. annotation is deprecated in 6.2 and will be going away in the future
You might try creating a line feature and label that with
repeatdistance. Or create a grid of points that you can use to position
you disclaimer labels with.
-Steve W
On 9/24/2012 5:17 AM, Andrea Peri wrote:
> Hi,
> I notice the repeatdistance don't work on a label of a type annotation
> layer.
> I read the doc.
> Seem the repeatdistance work only with a line layer.
> But I guess it could work also with the annotation.
> When the goal is the put many disclaimers on a map.
> Is this an enhancement feature or a bug of the actual repeatdistance
> command. ?
> This is my mapfile:
> LAYER
> NAME "rt_ofc.10k10.disclaimer"
> STATUS OFF
> TYPE ANNOTATION
> TRANSFORM LL
> FEATURE
> POINTS
> 80 -20
> END
> TEXT 'Disclaimer Map...'
> END
> METADATA
> "wms_title" "...."
> "wms_abstract" "..."
> "wms_layer_group" "..."
> END
> CLASS
> LABEL
> TYPE TRUETYPE
> FORCE true
> COLOR "#FFFFFF60"
> ANTIALIAS false
> PRIORITY 10
> SIZE 10
> ANGLE 0
> FONT "LiberationSans-Regular"
> POSITION UR
> REPEATDISTANCE 100 <--- seem don't work
> END
> END
> END
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
