[mapserver-users] [mapcache] Add OSM into TileCache
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 24 19:03:35 PDT 2012
Hi Hanks,
I have moved this discussion to the mapserver list so sub to it if you
have not already.
mapcache does not support input source s other than WMS at the moment.
BUT there is a hackish way to work around that if you need to:
You should be able to setup a mapserver WMS service with a LAYER using
GDAL 1.7.0+ configured to pull OSM tile server as input.
So mapserver requests the OSM tiles and assembles an image in response
to a WMS request it receives from mapcache and mapcache then chops the
image back into tiles and stores them in the cache in response to your
OpenLayers making tile requests to mapcache.
I have not done this but I suspect that it would work very well and
while it sounds convoluted it should not be that hard to figure out the
details if you ask on this list when you have a problem.
-Steve W
On 9/24/2012 8:29 PM, hz hanks wrote:
> Hey, All:
> I want to implement TileCache into my system. I installed TileCache
> successfully into my window server and can work well with default
> layer ( OpenLayers.Layer.WMS )
> Now I want to use OSM layer ( OpenLayers.Layer.OSM ) instead.
> I know I need to modify the config file, but things as following don't work:
> [osm]
> type=Mapnik
> mapfile=/home/user/osm-mapnik/osm.xml
> spherical_mercator=true
> tms_type=google
> metatile=yes
> Do I need to install Mapnik as well? Or I need to change the value of
> "mapfile" in Windows?
> Actually, the only thing I need is the cache functionality so I can
> use my map application even it's offline. ( The Cache proxy is
> installed in the same laptop with the web application, so the web
> application can always access to the Cache Proxy ) .
> Any suggestion on add OSM into TileCache or any light-weighted
> alternative of TileCache?
> Thanks a lot!
> Best,
> Hanks
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
