[mapserver-users] MapServer 6.2.0 beta2 release - WFS getcapabilities problem
Helen San Segundo Navazo hsansegundo at meteo.cat
Wed Sep 26 06:56:33 PDT 2012
Hi, I've download the mapserver-msautotest-970b31e and I've done the
getcapabilities request to the wfs_simple.map in both versions of
mapserver and the result is the same, with the 6.0.2 I have no problem
but with mapserver 6.2 beta2, wfs 1.1.0 not works.
this is the mapservers installation I have:
MapServer version 6.2.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
  MapServer version 6.0.2   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
El 26/09/12 14:21, thomas bonfort escribió:
> Sorry, not able to test this as the mapfile is missing some includes,
> and I am not setup to test oracle connections. please test this with a
> shapefile mapfile, and/or give more info as to what output you're
> getting on the failed request (no output at all, error message, ... ?)
> On Wed, Sep 26, 2012 at 2:07 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat>  wrote:
>> Hi,
>> I send you the map file.
>> Thanks,
>> Helen
>> El 26/09/12 13:49, thomas bonfort escribió:
>>> Helen,
>>> can you provide the mapfile you are using that exhibits this? Our
>>> tests on wfs capabilities show no abnormal failures between 1.0.0 and
>>> 1.1.0 getcaps requests:
>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs11_cap.xml
>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs_cap.xml
>>> thomas
>>> On Wed, Sep 26, 2012 at 1:32 PM, Helen San Segundo Navazo
>>>> Hi to all,
>>>> I've created some wfs on mapserver 6.0.2 and all of them work perfectly
>>>> with
>>>> the different requests and wfs versions 1.0.0 and 1.1.0.
>>>> I've pass from 6.0.2 to 6.2.0 beta2 release to solve the style request
>>>> problem with raster data sources and now I have problems with the wfs
>>>> getcapabilities request with 1.1.0 version.
>>>> With this 1.1.0 version I can't do getcapabilities request, I have no
>>>> response but there is no problem with describefeaturetype or getfeature
>>>> requests.
>>>> With the same 6.2.0 beta2 if I use wfs version= 1.0.0 there is no
>>>> problem.
>>>> Anybody knows wich can be the problem?
>>>> Thanks
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
