[mapserver-users] MapServer 6.2.0 beta2 release
Havard Tveite havard.tveite at umb.no
Thu Sep 27 01:28:28 PDT 2012
The behaviour of the GAP parameter has changed - before 6.2,
it specified some variation of the distance between the
bounding boxes of the symbols.  In 6.2 it specifies the
centre to centre distance between the symbols.
This change is described in the migration guide for 6.2,
which I can not find on mapserver.org/trunk (for some reason,
it is the 6.0 migration guide that is there).
https://github.com/mapserver/mapserver/blob/master/MIGRATION_GUIDE.txt
Håvard
On 8/7/2012 8:04 PM, Richard Greenwood wrote:
> thomas,
> So are the differences between the two images attached to my OP
> expected/intended when switching from GD to AGG rendering?
> Thanks,
> Rich
> On Tue, Aug 7, 2012 at 9:56 AM, thomas bonfort<thomas.bonfort at gmail.com>  wrote:
>> If you haven't specifically enabled GD (--enable-gd) then GIF will be
>> rendered with AGG in 6.2.
>> thomas
>> On Tue, Aug 7, 2012 at 5:52 PM, Richard Greenwood
>> <richard.greenwood at gmail.com>  wrote:
>>> Steve -
>>> Same OUTPUTFORMAT for both, and I don't even have an OUTPUTFORMAT
>>> definition for GIF so I'm using whatever the defaults are. Might my
>>> issue be related to GD versus AGG rendering? In other words, is the
>>> default GIF rendering done with GD in 6.0 and AGG in 6.2?
>>> Thanks,
>>> Rich
>>> On Mon, Aug 6, 2012 at 10:16 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com>  wrote:
>>>> What does your OUTPUTFORMAT block(s) look like? are you using the sameone
>>>> for both?
>>>> -Steve W
>>>> On 8/6/2012 11:06 PM, Richard Greenwood wrote:
>>>>> I'm having a problem with the rendering of one of my layers with 6.2.
>>>>> It's probably not a bug but rather that I'm doing something wrong. My
>>>>> map file:
>>>>> SYMBOL
>>>>>     NAME 'solid'
>>>>>     TYPE ellipse
>>>>>     POINTS 1 1 END
>>>>>     FILLED true
>>>>> END
>>>>> LAYER
>>>>>     CLASS
>>>>>       NAME "Zone X Shaded"
>>>>>       EXPRESSION /^X, SHADED/
>>>>>       STYLE
>>>>>         SYMBOL 'solid'
>>>>>         COLOR 128 128 128
>>>>>         GAP 1
>>>>>       END
>>>>>     END
>>>>> END
>>>>> See the two attached images for the different renderings.
>>>>> mapserv-6.0.gif is the desired rendering, mapserv-6.2.gif is the
>>>>> rendering of the same map file with MapServer 6.2 beta2.
>>>>> Any suggestions as to what I'm doing wrong?
>>>>> Thanks,
>>>>> Rich
>>>>> On Wed, Aug 1, 2012 at 3:51 AM, thomas bonfort<thomas.bonfort at gmail.com>
>>>>> wrote:
>>>>>> The MapServer Team is pleased to announce the release of MapServer
>>>>>> 6.2.0 beta2. This is the second beta on our way to a final 6.2 release,
>>>>>> and contains several fixes that we encourage you to test. Our initially
>>>>>> planned date of a release beginning of August has slipped a bit, the
>>>>>> updated release plan that can be viewed at
>>>>>> https://github.com/mapserver/mapserver/wiki/MapServer-6.2-Release-Plan
>>>>>> We however have only a few bugs left to resolve for our final release,
>>>>>> so we hope this beta phase will be over in the next couple of weeks.
>>>>>> The changelog since beta1 can be consulted here:
>>>>>> http://www.mapserver.org/en/development/changelog/changelog-6-2-0-beta2.html
>>>>>> The source for this release can be downloaded at:
>>>>>>      http://mapserver.org/download.html
>>>>>> or
>>>>>>      http://download.osgeo.org/mapserver/mapserver-6.2.0-beta2.tar.gz
>>>>>> The binary distributions listed in the download page should be updated
>>>>>> with binaries for the new 6.2.0-beta2 release in the next couple of days.
>>>>>> Once again we need your help to ensure a high quality product, so
>>>>>> please help out by testing your applications with this new code base.
>>>>>> Thanks! - The MapServer Team
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Richard Greenwood
>>> www.greenwoodmap.com
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
