[mapserver-users] How use the filteritem with a ogr spatialite db
Andrea Peri
aperi2007 at gmail.com
Thu Apr 4 12:29:38 PDT 2013
Hi Jukka,
after an update I try using
'default_idtpn' 'S%'
and surprising me it work !
Meanwhile I try to define the default as a simply %
'default_idtpn' '%'
but it don't work.
So it need not only a text field but a text field starting with a
character. Very rarely situation in our primarykey fields. :(
Thx for support,
Andrea.
2013/4/4 Rahkonen Jukka <jukka.rahkonen at mmmtike.fi>
> Hi Andrea,
> Could you make test by using something else than '9%' as variable default
> value, for example 'K9%'? We have had troubles with selecting atrribute
> values like "04.186.1.004" with SLD_BODY. We had to update the attributes
> into "K04.186.1.004" for making filtering to work. Obviously Mapserver was
> surprised in seeing two dots in a string that starts with a numeric
> character. Your type mismatch error makes me wonder if there could be
> something similar in your case.
> -Jukka Rahkonen-
> ________________________________
> Andrea Peri wrote:
> > Thx Steve.
> > It work ,
> > Just to do a step forward I try also to define as default a wildcard
> > using this sintax
> > I try settings like this:
> > FILTER "WHERE ID_ING = '%idtpn%' "
> > metadata
> > 'default_idtpn' '9%'
> > But the mapserver return an error.
> > msOGRFileWhichShapes(): OGR error. SetAttributeFilter(ID_ING LIKE '9%')
> failed on layer rt_speleologia.idingrotte.rt.
> > Type mismatch or improper type of arguments to LIKE operator.
> > Reading the gdal/ogr documentation this sintax should be allowed in the
> OGRSQL. I use gdal 1.9.1 and it seem to support the wildcard option.
> > So perhaps this could be a real bug of gdal.
> > I ask to gdal ML.
> 2013/4/4 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us<mailto:
> Steve.Lime at state.mn.us>>
> Filter should look like:
> FILTER (ID_ING = '%idtpn%' )
> If MapServer is to execute it, or:
> If OGR is to execute it.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org<mailto:
> mapserver-users-bounces at lists.osgeo.org> [mailto:
> mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Andrea Peri
> Sent: Thursday, April 04, 2013 8:26 AM
> To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] How use the filteritem with a ogr spatialite db
> Hi,
> I'm try-ing to apply a filter to a spatialite db by ogr .
> I try this
> CONNECTIONTYPE OGR
> CONNECTION "/.../tematici.sqlite"
> DATA "select
> PK_UID,ID_ING,ID_GRO,NUMERO,NOME,CODCOM,COMUNE,ANNO,DATA_AGG,SCHEDA,RILIEVO,CGBEST,CGBNORD,GEOMETRY
> from SPELEOLOGIA_INGRESSI_GROTTE"
> FILTER "(ID_ING = '%idtpn%' )"
> FILTERITEM 'ID_ING'
> VALIDATION
> 'idtpn' '^[a-zA-Z0-9\-_]+$'
> END
> METADATA
> 'default_idtpn' '901707'
> But it don't work.
> There is some sample of filter usage with ogr format ?
> thx,
> Andrea Peri
> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130404/63ad8529/attachment.html>
