[mapserver-users] adding gifs to index.html file?
Mark Mirrlees mmirrlees at hotmail.com
Thu Apr 4 17:17:47 PDT 2013
Here is my index.html file.
!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>Mark Mirrlees Assignment 4</title>
<body>
<center>
<img src="/wwwroot/M_Mirrlees_Assign4\bos.gif" width="150" height="100">
</head>
</body>
</html>
<Center>
<BR>
   <form method=GET action="/cgi-bin/mapserv.exe">
      <INPUT type="hidden" name="map" value="/wwwroot/M_Mirrlees_Assign4/global.map">
   <INPUT type="hidden" name="layer" value="provinces">
   <INPUT type="hidden" name="layer" value="states">
   <INPUT type="hidden" name="layer" value="cancity">
   <INPUT type="hidden" name="layer" value="usacity">
   <INPUT type="hidden" name="zoomdir" value=1>
   <INPUT type="hidden" name="zoomsize" value=2>
   <INPUT type="hidden" name="program" value="/cgi-bin/mapserv.exe">
   <INPUT type="submit" value="Launch the Map"/>
   </form>
<CENTER>
http://localhost/maps/M_Mirrlees_Assign4/ is what I type in my internet browser to launch my map.
Thanks,
Mark
To: mmirrlees at hotmail.com; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] adding gifs to index.html file?
Date: Thu, 4 Apr 2013 20:11:55 -0400
MapServer Message
Post the whole index.html here and give me
what you are putting into your browser to show the index.html
Worth
[mailto:mmirrlees at hotmail.com]
Sent: Thursday, April 04, 2013
8:02 PM
To: Worth Lutz;
Ok so I've tried both ways and
they both output another box. However this time with an X in the corner.
See attached.
Thanks,
Mark
Date: Thu, 4 Apr 2013 19:52:56 -0400
Try:
Or if “wwwroot” really is the web root:
<img src="/M_Mirrlees_Assign4\bos.gif"
Worth Lutz
mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org]
On Behalf Of Mark Mirrlees
7:17 PM
To: Rahkonen Jukka;
Subject: [mapserver-users] adding
Hi there,
Ok I figured that part out! Thanks! Your a lifesaver! I have one other question
I'm trying to add images (gif files) to my index.html file.
When I place this code into my html file it neglects to show the image...
<img src="file:/wwwroot/M_Mirrlees_Assign4\bos.gif" width="150"
height="100">
It shows a white box with a black like square in the corner (see image)...not
sure what i'm missing...any ideas?
Thanks,
Mark
To: mapserver-users at lists.osgeo.org
Date: Thu, 4 Apr 2013 07:55:41 +0000
Subject: Re: [mapserver-users] output issues (malformed template name)
The immediate reason
for the error  is that you do not have a referred template file in your
system
TEMPLATE
'fooOnlyForWMSGetFeatureInfo'
For correcting this
error you must change TEMPLATE to refer to something that exists. The template
file must contain at least the magic string ‘mapserver template’ in the first
line of the template http://www.mapserver.org/mapfile/template.html
However, I have a
feeling that this will not be enough for making your application to launch. If
this happens, please tell a bit more about your application, how it works and
what happens when you press the launch button.  And absolutely add
CONFIG
"MS_ERRORFILE" "c:\good_errorfile_path_for_you.txt” and
DEBUG 5 into your
mapfile.  This way you will get much valuable information into the
errorfile. Comment out the DEBUG line once everything works perfectly for you.
The PyQgis MapServer
Export plugin should really be fixed. At least it should write the
“wms_enable_request” metadata item. Now it does not and no mapfile created with
QGis will work for WMS without editing. Plugin is also using the deprecated
TRANSPARENCY and I  would rather see PROJECTION blocks to use
"init=epsg:xxxx" but that  may not be so important.  I am
not sure it the plugin writes always SYMBOLSET
"/wwwroot/symbols/symbols.sty" and uses SYMBOL "circle" in
some type of classes but if it does it can also lead to not working
mapfiles.  Is there anything else to complain? I can make a QGis feature
request once I have collected the most important things to correct and checked
that they have not been corrected already.
-Jukka Rahkonen-
Mark Mirrlees wrote:
Hello everyone,
I am trying to create a new map and it is causing me some output issues.
When I click my launch button to start the application it comes up with this
message
Content-type: text/html msReturnPage(): Web application error. Malformed
template name (fooOnlyForWMSGetFeatureInfo).
I have attached my mapfile and I do apologize for the length of it.
I'm not sure what's wrong in the map file! Any help would be greatly
appreciated!
Thanks,
Mark
_______________________________________________ mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.3267 / Virus Database: 3162/6224 - Release Date: 04/04/13
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130404/290c113d/attachment-0001.html>
