[mapserver-users] compile file geodatabase (.gdb)
cool_2x
cool_2x at yahoo.com
Sun Apr 7 21:15:54 PDT 2013
dear all, please help me,
I have successfuly call file geodatabse (.gdb) with quantum gis osgeo4w, but
when I running my webgis pmapper framework, I get error about
" Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection in layer `bloking1'. File not found or unsupported format. in
C:\OSGeo4W\apps\PTAPTP\sth\incphp\initgroups.php on line 314
Warning: Cannot modify header information - headers already sent by (output
started at C:\OSGeo4W\apps\PTAPTP\sth\incphp\initgroups.php:314) in
C:\OSGeo4W\apps\PTAPTP\sth\map_uilayout.phtml on line 56
mybe there is ever fix it.
I ever suggest for compile the file geodatabase as this link
"http://www.gdal.org/ogr/ogr_formats.html".. so i dont know how implement
this step :
You may compile filegdb as a plugin for GDAL:
1. Compile GDAL with the FGDB section commented
2. Now edit your nmake.opt (or add it in nmake.local) so it contains
something like the following (pay attention to the FGDB_SDK path):
FGDB_ENABLED = YES
FGDB_PLUGIN = YES
FGDB_SDK = $(GDAL_HOME)\..\FileGDB_API_VS2008_1_0Final
FGDB_INC = $(FGDB_SDK)\include
FGDB_LIB = $(FGDB_SDK)\lib\FileGDBAPI.lib
3. Next, cd to the /ogr/ogrsf_frmts/filegdb directory
4. Execute the following:
nmake /f makefile.vc plugin
A file named ogr_FileGDB.dll should be generated.
5. You will also need the file:
FileGDB_API_VS2008_1_0Final/bin/FileGDBAPI.dll
in section 2. I dont know what must I do, about path file folder or what..
please guide me step by step, if any one ever fix it..
thankyu
View this message in context: http://osgeo-org.1560.n6.nabble.com/compile-file-geodatabase-gdb-tp5045122.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
