[mapserver-users] How to pass variables to a query template?
Brent Fraser
bfraser at geoanalytic.com
Tue Apr 9 13:16:05 PDT 2013
Bob,
Since you are using PHP Mapscript, you have to add that step to your
PHP script yourself. You may be able to simply put the request array
into the parameter list:
$results = $map->processquerytemplate($_REQUEST, false);
or you may have to do some array massaging before passing the Request
keyword/values to the processquerytemplate function...
Best Regards,
Brent Fraser
On 4/9/2013 1:58 PM, Bistrais, Bob wrote:
> I have some code which sends query results to a template for display,
> using the MapServer processquerytemplate method. This works fine, but
> I'd also like to pass a variable to the template to be output in the
> result as well. I have been looking at the documentation on
> templates, http://mapserver.org/mapfile/template.html
> <http://mapserver.org/mapfile/template.html> , and saw the [post or
> get variable name]. This looks promising but I'm not sure how to use
> this with PHP-Mapscript. How does one do this?
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130409/313dafc4/attachment.html>
