[mapserver-users] PHP Mapscript query
Nicol Hermann
mapserver at geoworld.de
Wed Apr 10 13:43:06 PDT 2013
Steve,
thanks for your answer.
Probably you are right and something is wrong with my installation.
I will check it on an other system.
Thanks again
Nicol
Am Mittwoch, den 10.04.2013, 19:52 +0000 schrieb Lime, Steve D (MNIT):
> That error indicates a fundamental problem and I'm not even sure how you would trigger it. Basically it's generated when the type of queryObj passed to a query function is inappropriate for that particular function. Makes me wonder if your install might be mucked up.
> Do you have a simple test case that demonstrates the error?
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nicol Hermann
> Sent: Wednesday, April 10, 2013 1:36 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] PHP Mapscript query
> Hello,
> I am using PHP MapScript 6.2.0 and trying to execute a query.
> Regardless if I am trying a queryByRect or a queryByAttribut I am always getting the error message:
> 'The query is not properly defined'
> msQueryByRect(): Query error. The query is not properly defined.
> msQueryByAttribute(): Query error. The query is not properly defined
> The layer block look like this:
> LAYER
> NAME "plz"
> DATA plz
> STATUS DEFAULT
> TYPE POLYGON
> DEBUG 5
> CLASS
> NAME "zipcode"
> TEMPLATE "brd.html"
> STYLE
> COLOR 255 212 10
> END
> END
> END
> one of the query statements:
> $layer->queryByRect($map->extent);
> Does anybody know what I need to do to get ride of this error?
> As far as I understand this is not the error message when no items are found.
> Thank you very much
> Nicol
