[mapserver-users] Problems serving GeoTifs as .bil
Evans, James R Civ USAF ACC 84 RADES/SCZE James.Evans at hill.af.mil
Fri Apr 12 11:55:52 PDT 2013
I'm having bad results trying serve elevation data from GMTED2010 geotifs as .bil.  On the client side, the file I get is the right size, however only the low byte of the 16 bit word has any values.  The high 8 bits are always zero.  That has the effect of making all of my elevations appear to be between 0 and 255 meters.  If I try to download the data as 32 bit tifs, it works fine.  Unfortunately, my client app is looking for .bils.  Here's the start of my map file.  I'm using the MS4W latest released version.  Any help would be appreciated!
Thanks,
James
Here's what one of my requests looks like:
http://localhost/cgi-bin/gmted.exe?service=WMS&request=GetMap&version=1.1.1&srs=EPSG:4326&layers=GMTED&styles=&format=image/bil&width=150&height=150&bbox=-120.0,30.0,-100.0,50.0&
Start of my Map file:
MAP
  NAME "GMTED"
  EXTENT -180 -90 180 90
  SIZE 512 512
  UNITS DD
  IMAGETYPE image/bil
  PROJECTION
    "init=epsg:4326"
  END
  OUTPUTFORMAT
    NAME "asc"
    DRIVER "GDAL/AAIGrid"
    MIMETYPE "application/asc"
    EXTENSION "asc"
    IMAGEMODE INT16
  END
  OUTPUTFORMAT
    NAME "bil"
    DRIVER "GDAL/EHdr"
    MIMETYPE "image/bil"
    EXTENSION "bil"
    IMAGEMODE INT16
  END
  OUTPUTFORMAT
    NAME "bil16"
    DRIVER "GDAL/EHdr"
    MIMETYPE "application/bil16"
    EXTENSION "bil"
    IMAGEMODE INT16
  END
  OUTPUTFORMAT
    NAME "tif"
    DRIVER "GDAL/GTiff"
    MIMETYPE "image/tiff"
    EXTENSION "tif"
    IMAGEMODE FLOAT32
  END
  WEB
    METADATA
      wms_title "GMTED Terrain"
      wms_srs "EPSG:4326 EPSG:900913"
      ows_onlineresource "http://localhost/cgi-bin/GMTED"
      ows_enable_request "*"
    END
  END
