[mapserver-users] no results for wfs getfeature request
Martin Kofahl
martin.kofahl at gmail.com
Sat Apr 13 07:27:24 PDT 2013
Holger,
can you post the full request sent to MapServer?
Martin
2013/4/13 <porath at web.de>
> Hi all!
> Since we moved from mapserver 5.6.3 to 6.2.0 our WFS 1.0.0 getfeature
> requests do not work any more. We always get an empty result although the
> logged sql statement returns one record when executed directly in
> sqldeveloper. Please find an excerpt of the log below:
> msProjectRect(): Projection library error. All points failed to reproject.
> msOracleSpatialLayerGetPaging was called.
> msOracleSpatialLayerFreeItemInfo was called.
> msOracleSpatialLayerClose was called. Layer: 0x1a2ede0, Layer name: flst.
> Layer connection:/@ORCLTST
> msOracleSpatialLayerOpen. Shared connection not available. Creating one.
> msProjectRect(): Warning: degenerate rect
> {0.000000,0.000000,0.000000,0.000000}
> msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data: …
> msOracleSpatialLayerWhichShapes. Bind values: srid:-1
> minx:-2998554.423622 miny:478.980149 maxx:-2998554.423622
> maxy:478.980149
> msOracleSpatialLayerWhichShapes getting ordinate definition.
> msOracleSpatialLayerWhichShapes converting to OCIColl.
> msOracleSpatialLayerWhichShapes bind by name and object.
> msOracleSpatialLayerWhichShapes name and object now bound.
> msOracleSpatialLayerNextShape on layer 0x1a2ede0, row_num: 0
> msOracleSpatialLayerNextShape on layer 0x1a2ede0, row_num: 1
> msOracleSpatialLayerNextShape on layer 0x1a2ede0, Fetched 0 more rows (1
> total)
> Layer connection:
> msQueryByRect(): Search returned no results. No matching record(s) found.
> Layer connection:
> The same request works fine on mapserver 5.6.3.
> Any help is highly appreciated.
> Holger
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130413/fa65f631/attachment.html>
