[mapserver-users] geotiff resampling and transparency - artifact problem
thomas bonfort thomas.bonfort at gmail.com
Thu Apr 18 13:01:51 PDT 2013
Hi Oliver,
Are you using mapserver's OFFSITE parameter, and/or do your tiff files have
a nodata pixel set ?
What happens if you convert your tiff to 32bit RGBA? (Not suggesting this
is a valid workaround, just trying to narrow down the reasons for this).
thomas
On 18 April 2013 15:27, Oliver Christen <oliver.christen at camptocamp.com>wrote:
> dear all
> Im having some issue when applying PROCESSING "RESAMPLE=AVERAGE" or
> "RESAMPLE=BILINEAR" on some geotiff with transparency.
> Either a clear or dark artifact appears on the border of the image, as
> seen on these examples:
> http://dev.camptocamp.com/**files/mapserver/fuzzy_edge_**AVERAGE.png<http://dev.camptocamp.com/files/mapserver/fuzzy_edge_AVERAGE.png>
> http://dev.camptocamp.com/**files/mapserver/fuzzy_edge_**BILINEAR.png<http://dev.camptocamp.com/files/mapserver/fuzzy_edge_BILINEAR.png>
> if I specify no PROCESSING at all, the transparency is correct (but not
> the image "quality" which I wanted to improve with the PROCESSING ):
> http://dev.camptocamp.com/**files/mapserver/fuzzy_edge_**NOPROCESSING.png<http://dev.camptocamp.com/files/mapserver/fuzzy_edge_NOPROCESSING.png>
> at first I though the problem may have been caused by a fuzzy edge on the
> transparent edges in the geotiff:
> http://dev.camptocamp.com/**files/mapserver/fuzzy_edge.png<http://dev.camptocamp.com/files/mapserver/fuzzy_edge.png>
> so I retreated one image to have clean edges:
> http://dev.camptocamp.com/**files/mapserver/clean_edge.png<http://dev.camptocamp.com/files/mapserver/clean_edge.png>
> but I couldnt see much difference in the result:
> http://dev.camptocamp.com/**files/mapserver/clean_edge_**AVERAGE.png<http://dev.camptocamp.com/files/mapserver/clean_edge_AVERAGE.png>
> http://dev.camptocamp.com/**files/mapserver/clean_edge_**BILINEAR.png<http://dev.camptocamp.com/files/mapserver/clean_edge_BILINEAR.png>
> there is no visible artifact for all border multipe of 90° (horizontal and
> vertical edges), only the non 90° edges show that problem.
> Im not knowledgeable with image manipulation and resampling with
> transaprency, so I dont know if this is normal or not.
> Any idea if there is some way to "solve" this "problem" ?
> thank you for your attention
> best regards
> Oliver
> Camptocamp SA
> Oliver Christen
> PSE A
> CH-1015 Lausanne
> www.camptocamp.com
> +41 21 619 10 23 (direct)
> +41 21 619 10 10 (centrale)
> +41 21 619 10 00 (fax)
> ______________________________**_________________
> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130418/3c72f0af/attachment.html>
