[mapserver-users] still no results for wfs getfeature request
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Apr 22 06:00:36 PDT 2013
Any chance you could run it against a shapefile version of the data? I'm curious if this could be Oracle specific.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Holger Porath [porath at web.de]
Sent: Saturday, April 20, 2013 4:59 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] still no results for wfs getfeature request
Hi all!
We still do not get any results for wfs 1.0.0 getfeature filter requests when using map server 6.2.0
Let me summarize what we have found out so far:
The same filter request works correctly when wfs version 1.1.0 is used (instead of 1.0.0) .
The same filter request works correctly when map server 5.6.3 is used (even when using wfs version 1.0.0).
A wfs bbox request (no filter) works correctly.
Here is the filter request that does not work:
http://host/ogc-sec-data.ows?service=WFS&version=1.0.0&request=getFeature&typeName=flst_gdsrvt01&Filter=%3CFilter%3E%0A%3Cand%3E%0A%3CPropertyIsLike%20wildCard%3D%22%25%22%20singleChar%3D%22%3F%22%20escape%3D%22ESC%22%3E%0A%3CPropertyName%3EFS_GKNR%3C%2FPropertyName%3E%0A%3CLiteral%3E534%3C%2FLiteral%3E%0A%3C%2FPropertyIsLike%3E%0A%3CPropertyIsLike%20wildCard%3D%22%25%22%20singleChar%3D%22%3F%22%20escape%3D%22ESC%22%3E%0A%3CPropertyName%3EFS_FLNR%3C%2FPropertyName%3E%0A%3CLiteral%3E26%3C%2FLiteral%3E%0A%3C%2FPropertyIsLike%3E%0A%3CPropertyIsLike%20wildCard%3D%22%25%22%20singleChar%3D%22%3F%22%20escape%3D%22ESC%22%3E%0A%3CPropertyName%3EFS_FSZ%3C%2FPropertyName%3E%0A%3CLiteral%3E111%3C%2FLiteral%3E%0A%3C%2FPropertyIsLike%3E%0A%3C%2Fand%3E%0A%3C%2FFilter%3E
The layer is configured as shown below:
LAYER
DEBUG 10
NAME flst
METADATA
"wfs_title" "flst"
"gml_featureid" "fs_id"
"gml_include_items" "all"
"wfs_extent" "400000.000000 5400000.000000 600000.000000 5800000.000000"
"wfs_abstract" "Test"
END
DUMP TRUE
PROJECTION
"init=epsg:25832"
END
CONNECTIONTYPE oraclespatial
CONNECTION "user/pass at ORCLTST"
DATA "fs_tpo_pos from (select fs_tpo_pos,
fs_gknr,
fs_flnr,
fs_fsz,
fs_fsn,
fs_fsstatus,
gk_gkbez,
fs_id
from nav.flst,
nav.gmkg
where gk_gknr=fs_gknr and
fs_fsstatus='a')
USING UNIQUE fs_id NONE VERSION 9i"
TYPE POINT
STATUS ON
END
There is a suspicious message in the log file saying "projection library error. All points failed to reproject". Is it possible that that's the reason? What does it mean?
msProjectRect(): Projection library error. All points failed to reproject.
msOracleSpatialLayerGetPaging was called.
msOracleSpatialLayerFreeItemInfo was called.
msOracleSpatialLayerClose was called. Layer: 0x1a2ede0, Layer name: flst. Layer connection:/@ORCLTST
msOracleSpatialLayerOpen. Shared connection not available. Creating one.
msProjectRect(): Warning: degenerate rect {0.000000,0.000000,0.000000,0.000000}
msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data: …
msOracleSpatialLayerWhichShapes. Bind values: srid:-1 minx:-2998554.423622 miny:478.980149 maxx:-2998554.423622 maxy:478.980149
msOracleSpatialLayerWhichShapes getting ordinate definition.
msOracleSpatialLayerWhichShapes converting to OCIColl.
msOracleSpatialLayerWhichShapes bind by name and object.
msOracleSpatialLayerWhichShapes name and object now bound.
msOracleSpatialLayerNextShape on layer 0x1a2ede0, row_num: 0
msOracleSpatialLayerNextShape on layer 0x1a2ede0, row_num: 1
msOracleSpatialLayerNextShape on layer 0x1a2ede0, Fetched 0 more rows (1 total)
msQueryByRect(): Search returned no results. No matching record(s) found.
Any help is very appreciated. Thanks in advance.
Holger
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
