[mapserver-users] Mapserver 6.2.1 fails to read remote WMS in png format
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 25 07:26:47 PDT 2013
What if you try to gdal_translate it to a TIFF or JPEG for instance?
Please make sure you use the gdal_translate tool from the exact same
MS4W package as what your MapServer is using.
Daniel
On 13-04-25 10:17 AM, Rahkonen Jukka wrote:
> Hi,
> Yes, I have checked that png files saved from both services I have been testing are OK. I know that our own server is using this outputformat
> OUTPUTFORMAT
> NAME 'AGG_Q'
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE RGB
> FORMATOPTION "QUANTIZE_FORCE=ON"
> FORMATOPTION "QUANTIZE_DITHER=OFF"
> FORMATOPTION "QUANTIZE_COLORS=256"
> GDAL 1.10dev understands the saved image this way:
> E:\>gdalinfo temp.png
> Driver: PNG/Portable Network Graphics
> Files: temp.png
> Size is 459, 353
> Coordinate System is `'
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 353.0)
> Upper Right ( 459.0, 0.0)
> Lower Right ( 459.0, 353.0)
> Center ( 229.5, 176.5)
> Band 1 Block=459x1 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 62,135,124,255
> 1: 52,108,102,255
> 2: 46,110,106,255
> 3: 58,131,122,255
> 4: 78,153,135,255
> 5: 50,110,102,255
> 6: 52,116,106,255
> 7: 50,108,102,255
> 8: 54,116,110,255
> 9: 213,213,201,255
> 10: 223,247,239,255
> 11: 66,143,131,255
> 12: 52,110,106,255
> 13: 64,139,122,255
> 14: 76,149,133,255
> 15: 64,126,116,255
> 16: 52,124,112,255
> 17: 54,129,118,255
> 18: 76,149,124,255
> 19: 74,141,124,255
> 20: 82,151,135,255
> 21: 94,151,135,255
> 22: 76,143,131,255
> 23: 82,147,131,255
> 24: 50,106,102,255
> 25: 74,151,131,255
> 26: 74,147,129,255
> 27: 62,139,124,255
> 28: 72,141,118,255
> 29: 44,104,100,255
> 30: 141,110,116,255
> 31: 84,151,126,255
> 32: 94,151,131,255
> 33: 64,129,120,255
> 34: 163,143,135,255
> 35: 46,108,102,255
> 36: 60,131,120,255
> 37: 137,102,100,255
> 38: 88,155,133,255
> 39: 114,124,112,255
> 40: 90,126,102,255
> 41: 110,118,104,255
> 42: 76,131,118,255
> 43: 149,133,126,255
> 44: 88,159,139,255
> 45: 82,147,124,255
> 46: 106,151,122,255
> 47: 100,157,135,255
> 48: 50,116,110,255
> 49: 171,145,147,255
> 50: 145,181,157,255
> 51: 157,129,126,255
> 52: 90,141,120,255
> 53: 90,149,126,255
> 54: 157,139,135,255
> 55: 139,122,114,255
> 56: 161,143,141,255
> 57: 84,147,122,255
> 58: 147,112,116,255
> 59: 100,165,145,255
> 60: 163,131,133,255
> 61: 139,108,108,255
> 62: 76,141,126,255
> 63: 147,122,118,255
> 64: 46,106,102,255
> 65: 72,145,120,255
> 66: 151,149,135,255
> 67: 135,124,120,255
> 68: 84,143,116,255
> 69: 141,139,131,255
> 70: 163,165,153,255
> 71: 135,163,141,255
> 72: 106,104,96,255
> 73: 72,149,131,255
> 74: 177,135,135,255
> 75: 161,159,147,255
> 76: 163,149,147,255
> 77: 82,145,126,255
> 78: 157,126,133,255
> 79: 193,159,159,255
> 80: 100,139,110,255
> 81: 181,147,149,255
> 82: 151,122,124,255
> 83: 141,126,122,255
> 84: 161,199,175,255
> 85: 157,177,159,255
> 86: 177,118,100,255
> 87: 185,157,157,255
> 88: 183,161,157,255
> 89: 169,126,126,255
> 90: 114,104,102,255
> 91: 171,159,149,255
> 92: 151,163,149,255
> 93: 106,139,120,255
> 94: 153,183,159,255
> 95: 171,145,141,255
> 96: 151,155,147,255
> 97: 161,124,126,255
> 98: 151,143,135,255
> 99: 52,129,116,255
> 100: 135,155,135,255
> 101: 124,155,135,255
> 102: 189,183,173,255
> 103: 135,102,106,255
> 104: 96,151,122,255
> 105: 54,120,112,255
> 106: 167,139,135,255
> 107: 139,102,108,255
> 108: 100,161,137,255
> 109: 114,92,92,255
> 110: 171,199,179,255
> 111: 177,147,147,255
> 112: 137,135,124,255
> 113: 171,157,155,255
> 114: 151,155,141,255
> 115: 139,163,149,255
> 116: 108,88,84,255
> 117: 203,183,173,255
> 118: 171,167,157,255
> 119: 179,229,205,255
> 120: 153,187,167,255
> 121: 131,92,98,255
> 122: 183,243,221,255
> 123: 131,110,112,255
> 124: 163,181,167,255
> 125: 179,205,189,255
> 126: 161,205,183,255
> 127: 181,189,175,255
> 128: 175,219,195,255
> 129: 173,179,167,255
> 130: 181,175,165,255
> 131: 179,163,159,255
> 132: 163,157,151,255
> 133: 161,217,193,255
> 134: 161,120,120,255
> 135: 177,157,151,255
> 136: 173,187,173,255
> 137: 139,147,135,255
> 138: 149,139,133,255
> 139: 126,88,92,255
> 140: 161,189,171,255
> 141: 52,122,112,255
> 142: 171,151,147,255
> 143: 145,187,167,255
> 144: 126,122,114,255
> 145: 96,98,92,255
> 146: 131,141,131,255
> 147: 58,131,120,255
> 148: 126,147,131,255
> 149: 173,175,161,255
> 150: 94,86,82,255
> 151: 161,153,145,255
> 152: 167,131,135,255
> 153: 137,179,153,255
> 154: 108,76,82,255
> 155: 122,104,100,255
> 156: 151,118,120,255
> 157: 163,171,157,255
> 158: 163,135,135,255
> 159: 124,118,108,255
> 160: 124,137,122,255
> 161: 80,86,80,255
> 162: 131,100,100,255
> 163: 177,139,143,255
> 164: 161,149,141,255
> 165: 76,68,70,255
> 166: 151,118,122,255
> 167: 137,161,145,255
> 168: 171,133,135,255
> 169: 106,72,76,255
> 170: 82,141,120,255
> 171: 151,199,173,255
> 172: 94,70,72,255
> 173: 157,133,133,255
> 174: 110,82,82,255
> 175: 141,120,120,255
> 176: 94,157,135,255
> 177: 72,100,96,255
> 178: 151,112,114,255
> 179: 143,171,153,255
> 180: 122,92,98,255
> 181: 114,98,94,255
> 182: 114,84,90,255
> 183: 70,145,126,255
> 184: 147,116,118,255
> 185: 149,133,133,255
> 186: 120,88,90,255
> 187: 153,171,155,255
> 188: 129,126,120,255
> 189: 106,90,90,255
> 190: 86,151,135,255
> 191: 139,116,112,255
> 192: 135,171,149,255
> 193: 84,157,135,255
> 194: 129,110,106,255
> 195: 58,126,118,255
> 196: 92,139,110,255
> 197: 151,145,141,255
> 198: 72,139,120,255
> 199: 171,135,141,255
> 200: 141,108,112,255
> 201: 76,149,129,255
> 202: 163,137,141,255
> 203: 58,122,114,255
> 204: 171,141,143,255
> 205: 157,120,124,255
> 206: 135,153,141,255
> 207: 153,126,131,255
> 208: 62,137,122,255
> 209: 84,139,110,255
> 210: 149,126,126,255
> 211: 90,147,120,255
> 212: 147,106,110,255
> 213: 124,98,98,255
> 214: 126,104,106,255
> 215: 82,151,131,255
> 216: 82,155,131,255
> 217: 46,104,100,255
> 218: 82,141,126,255
> 219: 42,102,98,255
> 220: 48,116,108,255
> 221: 44,114,106,255
> 222: 68,147,129,255
> 223: 86,149,131,255
> 224: 58,120,112,255
> 225: 163,126,131,255
> 226: 72,147,124,255
> 227: 48,114,106,255
> 228: 56,131,118,255
> 229: 74,139,114,255
> 230: 46,102,98,255
> 231: 54,126,116,255
> 232: 50,110,106,255
> 233: 68,141,129,255
> 234: 58,135,124,255
> 235: 66,139,126,255
> 236: 78,153,131,255
> 237: 70,143,124,255
> 238: 58,116,110,255
> 239: 40,98,96,255
> 240: 52,124,116,255
> 241: 60,122,114,255
> 242: 42,104,100,255
> 243: 44,110,104,255
> 244: 54,116,108,255
> 245: 82,143,131,255
> 246: 66,143,129,255
> 247: 64,137,118,255
> 248: 62,137,124,255
> 249: 60,135,122,255
> 250: 48,120,112,255
> 251: 62,139,126,255
> 252: 54,112,106,255
> 253: 56,133,122,255
> 254: 46,108,102,255
> 255: 255,255,255,255
> -Jukka-
> Daniel Morissette wrote:
>> Hi Jukka,
>> IIRC, a few releases ago (not sure if that was in 6.0 or before) we got rid of all
>> native raster reading code in MapServer and started relying solely on GDAL
>> for raster input. i.e. before that we used to read PNG input directly in
>> MapServer code using libpng, and now we do it through GDAL. That could
>> possibly explain why you get different behaviors, but doesn't explain why
>> your PNG cannot be read by GDAL.
>> Two things to check:
>> 1- Does the image/png request captured from the logs work from the server
>> machine (using wget for instance)? Does it return a valid PNG image?
>> 2- Save the output of that request with a command such as "wget https://... -
>> O /tmp/test.png" and try running gdalinfo on the output.
>> Maybe that will give some hints.
>> Daniel
>> On 13-04-25 8:05 AM, Rahkonen Jukka wrote:
>>> Hi,
>>> I was testing Mapserver 6.2.1 from the MS4W 3.0.1beta-1 installation and
>> thought that there was something wrong with the connection. However, the
>> problem seems to be in Mapserver side. I have been using
>> &FORMAT=image/png for reading the remote WMS with Mapserver 6.0.1
>> but with MS 6.2.1 it does not work. After changing image format into
>> image/jpeg Mapserver can again cascade the remote WMS.
>>> Part of the errorlog is in the attachment but the most relevant parts
>>> are here
>>> This request with FORMAT=image/jpeg works
>>> [Thu Apr 25 14:30:24 2013].970000 HTTP request: id=1,
>> https://...&FORMAT=image/jpeg&STYLES=&HEIGHT=353&VERSION=1.1.1&S
>> RS=EPS
>> G:3067&WIDTH=459&BBOX=406810.908602495,7216210.70370872,407078.361
>> 0453
>> 37,7216416.39153513&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.o
>> gc.se
>>> _inimage
>>> [Thu Apr 25 14:30:27 2013].354000 msDrawRasterLayerGDAL():
>>> red,green,blue,alpha bands = 1,2,3,0 [Thu Apr 25 14:30:27 2013].372000
>>> msDrawMap(): Layer 1 (test), 0.022s [Thu Apr 25 14:30:27 2013].372000
>>> msDrawMap(): Drawing Label Cache, 0.000s [Thu Apr 25 14:30:27
>>> 2013].372000 msDrawMap() total time: 2.408s [Thu Apr 25 14:30:27
>>> 2013].590000 msSaveImage(stdout) total time: 0.218s [Thu Apr 25
>>> 14:30:27 2013].592000 mapserv request processing time (msLoadMap not
>>> incl.): 2.629s
>>> This request with FORMAT=image/png does not work
>>> [Thu Apr 25 14:31:13 2013].915000 HTTP request: id=1,
>> https://...&FORMAT=image/png&STYLES=&HEIGHT=353&VERSION=1.1.1&SR
>> S=EPSG
>> :3067&WIDTH=459&BBOX=406508.434778249,7215858.43375314,407593.6153
>> 7966
>> 5,7216693.00619824&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.og
>> c.se_
>>> inimage
>>> [Thu Apr 25 14:31:18 2013].349000 msDrawRasterLayerGDAL():
>>> red,green,blue,alpha bands = 1,0,0,0 [Thu Apr 25 14:31:18 2013].349000
>>> drawGDAL(): Unable to access file. GDALDatasetRasterIO() failed:
>> GetBlockRef failed at X block offset 0, Y block offset 0 [Thu Apr 25 14:31:18
>> 2013].349000 msDrawMap(): WMS connection error. Failed to draw WMS
>> layer named 'test'. This most likely happened because the remote WMS
>> server returned an invalid image, and XML exception or another unexpected
>> result in response to the GetMap request. Also check and make sure that the
>> layer's connection URL is valid.
>>> [Thu Apr 25 14:31:18 2013].349000 mapserv request processing time
>>> (msLoadMap not incl.): 4.441s
>>> It looks like GDAL cannot find correct bands from the png output of the
>> remote WMS: " msDrawRasterLayerGDAL(): red,green,blue,alpha bands =
>> 1,0,0,0". However, Mapserver 6.0.1 with GDAL 1.8 can cascade this service
>> fine and all my WMS clients work well with the remote WMS by using
>> image/png format. I made also another test by trying to cascade our own
>> Mapserver 6.0.1 and the result was the same: if I read data as image/png
>> remote WMS I get the "GDALDatasetRasterIO() failed" error.
>>> I am not sure if this is Mapserver, GDAL or MS4W bug. Any opinions?
>>> -Jukka Rahkonen-
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Daniel Morissette
>> http://www.mapgears.com/
>> Provider of Professional MapServer Support since 2000
Daniel Morissette
