[mapserver-users] Mapserver 6.2.1 upgrade breaks Mapcache
aboudreault at mapgears.com aboudreault at mapgears.com
Fri Apr 26 05:59:27 PDT 2013
I pushed the proper update in UbuntuGIS for this issue. Should be published in a hour or so. However, I'm not sure to understand why your reinstall fixed your issue.
Thanks,
Alan
-----Original Message-----
Sent: Friday, April 26, 2013 8:31am
To: "'thomas bonfort'" <thomas.bonfort at gmail.com>
Cc: "'MapserverList OSGEO'" <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Mapserver 6.2.1 upgrade breaks Mapcache
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
I am using mapcache from ubuntu-gis-unstable.
I solved my problem by reinstalling mapcache with apt-get remove/install.
Should this problem be documented somewhere?  Is it just a problem with
ubuntu-gis-unstable?
In any case I'm back up and running.
Worth
  _____
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Friday, April 26, 2013 8:20 AM
To: Worth Lutz
Cc: MapserverList OSGEO
Native MapServer support in mapcache is considered experimental and
shouldn't really be enabled in production unless you know what you're doing.
That said...
- are you using mapcache from the ubuntu-gis repo?
 - if not, and you do not need native mapserver support, then recompile
mapcache without mapserver support
 - otherwise, you can probably just symlink  <http://libmapserver-6.2.0.so/>
libmapserver-6.2.0.so to  <http://libmapserver-6.2.0.so/>
libmapserver-6.2.1.so
thomas
On 26 April 2013 14:10, Worth Lutz <wal3 at mindspring.com> wrote:
I upgraded my Ubuntu (12.04) system today and MapServer upgraded to 6.2.1.
sudo apt-get upgrade
upgraded packages: cgi-mapserver mapserver-bin php5-mapscript
I tried to restart apache2 to update my MapCache config and it failed with:
Cannot load /usr/lib/apache2/modules/mod_mapcache.so into server:
libmapserver-6.2.0.so: cannot open shared object file: No such file or
directory
Action 'configtest ' failed.
Do I need to reinstall MapCache? What is the procedure to fix this? How can
I avoid this problem in the future?
Thanks,
Worth
  _____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.3272 / Virus Database: 3162/6273 - Release Date: 04/25/13
