[mapserver-users] Can't draw points from shapefile
Brent Fraser bfraser at geoanalytic.com
Sat Aug 3 08:23:55 PDT 2013
Michael,
   A minor point: Change UNITS DD in the map portion (UNITS, EXTENT, and
PROJECTION are all related).
   But the basic problem is a lack of a SYMBOL object in the STYLE
object of the points layer.  I didn't think it was necessary (it wasn't
in some previous versions?).  Back in the day, I thought the default was
SYMBOL 0 which was defined as a filled circle therefore no explicit
definition or reference required in the map file.  It looks like this is
no longer the case.
   So the solution is to add a symbol definition to the map file
(between the WEB and LAYER objects):
   #Circle symbol
   SYMBOL
     NAME 'CIRCLE'
     TYPE ellipse
     FILLED true
     POINTS
       1 1
     END
   END
and add a reference to it in the LAYER's STYLE object:
             STYLE
                 SYMBOL 'CIRCLE'
                 COLOR        255 1 1
             END
Best Regards,
Brent Fraser
On 8/1/2013 12:06 PM, Michael McInnis wrote:
> I have not been able to draw basic points from a shapefile. I can draw
> lines and polygons.
> Does anyone see a problem with the hwypoints layer?
> What is the minimal layer definition to display shapefile points?
> Thanks
> PS - shapefile points draw in QGIS.
> MAP
>     DEBUG 5
>     CONFIG "MS_ERRORFILE" "/media/D_Drive/www/gis/logs/error_file.log"
>     EXTENT            -180 -90 180 90
>     IMAGECOLOR    153 179 204
>     IMAGETYPE    PNG24
>     SHAPEPATH    data/
>     FONTSET        data/fonts/fonts.list
>     UNITS        MILES
>     SIZE 1000 1000    # Added
>     PROJECTION
>           #"+proj=mill +units=m"
>         "+proj=longlat +ellps=WGS84"
>     END
>     OUTPUTFORMAT
>         NAME        png
>         DRIVER        "AGG/PNG"
>         MIMETYPE    "image/png"
>         IMAGEMODE    RGBA
>         EXTENSION    "png"
>     END
>     WEB
>         #IMAGEPATH    "/home/www/gis/tmp/"
>         IMAGEPATH    "/media/D_Drive/www/gis/tmp/"
>         IMAGEURL    "gis/tmp/"
>     END
>     # good
>     LAYER
>         DATA            "world_noUSA"
>         NAME            "world"
>         TYPE            POLYGON
>         STATUS            ON
>         LABELITEM        "NAME"
>         CLASS
>             STYLE
>                 COLOR            217 223 195
>                 OUTLINECOLOR    181 190 148
>             END
>             LABEL
>                 FONT                "arial"
>                 PARTIALS            false
>                 #TYPE                truetype
>                 SIZE                8
>                 MINFEATURESIZE        20
>                 MINDISTANCE            1000
>                 COLOR                123 130 140
>             END
>         END
>         PROJECTION
>         END
>     END
>     # good
>     LAYER
>         DATA            "hwypoints"
>         NAME            "hwypoints"
>         TYPE            POINT
>         STATUS            ON
>         LABELITEM        "HWYNUMBER"
>         CLASS
>             STYLE
>                 #COLOR        255 1 1
>                 #OUTLINECOLOR    181 190 148
>             END
>             LABEL
>                 FONT                "arial"
>             #    PARTIALS            false
>             #    #TYPE                truetype
>                 SIZE                8
>             #    MINFEATURESIZE            20
>             #    MINDISTANCE            1000
>                 COLOR                123 130 140
>             END
>         END
>         PROJECTION
>         END
>     END
>     # good
>     LAYER
>         NAME        "us_interstate"
>         DATA        "US-Interstate-Low"
>         TYPE        LINE
>         STATUS        ON
>         CLASS
>             #MINSCALEDENOM            300000
>             STYLE
>                 COLOR        190 87 99
>                 SIZE         1
>                 #SYMBOL         "line"
>                 ANTIALIAS     TRUE
>             END
>         END
>         CLASS
>             #MAXSCALEDENOM            300000
>             STYLE
>                 COLOR        190 87 99
>                 SIZE         2
>                 #SYMBOL         "line"
>                 ANTIALIAS     TRUE
>             END
>         END
>         CLASS
>             #MINSCALEDENOM            2000
>             STYLE
>                 COLOR        150 47 59
>                 SIZE        4
>                 #SYMBOL         "line"
>                 ANTIALIAS     TRUE
>             END
>         END
>         PROJECTION
>         END
>     END
> END
> Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130803/5815a1c6/attachment.html>
