[mapserver-users] Still can't draw points
Michael McInnis
mmcinnis59 at msn.com
Mon Aug 5 12:21:06 PDT 2013
YES!
I find it odd that points are the only type that require a separately defined symbol in order to see a graphical product.I was able to draw polygons and lines without this extra step.
But thanks so much for pointing this out, now I can draw all my data!
Michael McInnis
6033 44th Ave. N.E.
Seattle, WA 98115
206 517-4701
> From: jukka.rahkonen at mmmtike.fi
> To: mmcinnis59 at msn.com; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Still can't draw points
> Date: Mon, 5 Aug 2013 19:12:21 +0000
> Hi,
> You have still not defined the symbol "square" that you want to used for drawing.
> Here comes a quick and not polished example that I have modified from your mapfile. It shows points for me with OpenJUMP with my data "roskis.shp".
> MAP
> DEBUG 5
> CONFIG "MS_ERRORFILE" "c:\ms4w\tmp\points_error.txt"
> CONFIG "PROJ_LIB" "C:/ms4w/proj/nad"
> EXTENT -180 -90 180 90
> #IMAGECOLOR 153 179 204
> IMAGETYPE PNG24
> SHAPEPATH "c:\ms4w\tmp"
> #FONTSET data/fonts/fonts.list
> UNITS DD
> SIZE 1000 500 # Added
> PROJECTION
> "init=epsg:4326"
> END
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> END
> WEB
> METADATA
> "ows_enable_request" "*"
> "wms_bbox_extended" "true"
> "wms_srs" "EPSG:4326"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?map=c:\ms4w\apps\points.map"
> "wms_title" "Draw points example"
> END
> END
> SYMBOL
> NAME 'CIRCLE'
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> LAYER
> NAME "city"
> TYPE POINT
> STATUS DEFAULT
> DATA "c:\data\osm\waste_baskets.shp"
> METADATA
> END
> CLASS
> STYLE
> SYMBOL "CIRCLE"
> SIZE 10
> COLOR 255 1 1
> OUTLINECOLOR 0 0 0
> END
> END
> END
> END
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Michael McInnis [mmcinnis59 at msn.com] puolesta
> Lähetetty: 5. elokuuta 2013 21:05
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Still can't draw points
> Dear mapserver-users,
> This is a follow on question to my post friday. I made some changes suggested by Brent Fraser
> but still haven't had a graphical success. I think something very basic is wrong with my set up for points.
> Here is my new attempt, which still fails. I looked in the error log and it
> seems to be treating the SYMBOL 'square' as a shapefile and says "unable to
> open file".
> Thanks
> MAP
> DEBUG 5
> CONFIG "MS_ERRORFILE" "/media/D_Drive/www/gis/logs/error_file.log"
> IMAGETYPE PNG24
> SHAPEPATH data/
> UNITS DD
> PROJECTION
> "+proj=longlat +ellps=WGS84"
> END
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> IMAGEMODE RGBA
> EXTENSION "png"
> END
> WEB
> IMAGEPATH "/media/D_Drive/www/gis/tmp/"
> IMAGEURL "gis/tmp/"
> END
> LAYER
> NAME "city"
> TYPE POINT
> STATUS DEFAULT
> DATA "CityALL"
> CLASS
> STYLE
> SYMBOL "square"
> SIZE 10
> COLOR 255 1 1
> OUTLINECOLOR 0 0 0
> END
> END
> END
> END
> Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130805/4fef593b/attachment.html>
