[mapserver-users] Fwd: confirm b8dc1607cc0cb601c5a4f9763f3a015f2a57a6d0
Carlos Isaac Otero Michilot
carlos.otero23 at gmail.com
Wed Aug 7 16:12:20 PDT 2013
Hello
Dear friends
I've been working with mapserver since 2005, but I've always had problems
when compiling newer versions of mapserver and this is one of these cases
with the 6.2.1 version.
H einstalado and all dependencies compiled mapserver with the following
script, including support for svg symbols.
./configure \
--with-proj=/usr/local \
--with-geos=/usr/local/bin/geos-config \
--with-ogr=/usr/local/bin/gdal-config \
--with-gdal=/usr/local/bin/gdal-config \
--with-zlib=/usr/lib/ \
--with-pkg-config=/usr/bin/pkg-config \
--with-mysql=/usr/bin/mysql_config \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-curl-config=/usr/bin/curl-config \
--with-apache-module \
--with-apxs=/usr/local/apache2/bin/apxs \
--with-fastcgi \
--with-php=/usr/local/apache2/php/bin/php-config \
--with-wfs \
--with-wfsclient \
--with-exempi \
--with-fribidi-config=/usr/local/lib/pkgconfig/fribidi.pc \
--with-wmsclient \
--enable-debug \
--with-threads \
--with-wcs \
--with-kml=yes \
--with-cairo=/usr/local/lib/pkgconfig/cairo.pc \
--with-sos \
--with-gd=/usr/bin/gdlib-config \
--with-freetype \
--with-jpeg \
--with-xml2-config=/usr/bin/xml2-config \
--with-xml-mapfile=yes \
--enable-proj-fastpath \
MapServer is now configured for i686-pc-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -Wall -Wdeclaration-after-statement
C++ compiler: g++ -g -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support:
png support: -DUSE_PNG
gif support: -DUSE_GIF
jpeg support: -DUSE_JPEG
freetype support: -DUSE_FREETYPE
iconv support: -DUSE_ICONV
AGG support: internal
GD support: -DUSE_GD -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_GIF
Cairo (SVG,PDF) support: -DUSE_CAIRO
Cairo SVG symbol support: -DUSE_SVG_CAIRO
KML support: -DUSE_KML
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Proj Fastpaths: -DUSE_PROJ_FASTPATHS
Libxml2 support: -DUSE_LIBXML2
FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
FastCGI support: -DUSE_FASTCGI
Exempi support: -DUSE_EXEMPI
Threading support: -DUSE_THREAD
GEOS support: -DUSE_GEOS
XML Mapfile support: -DUSE_XMLMAPFILE
XSLT support: -DUSE_XSLT
EXSLT support: -DUSE_EXSLT
-------------- Data Format Drivers -------
PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server: -DUSE_WFS_SVR
WFS Client: -DUSE_WFS_LYR
WCS Server: -DUSE_WCS_SVR
SOS Server: -DUSE_SOS_SVR
-------------- MapScript -----------------
PHP MapScript: yes
Python MapScript: no
But it throws the following error:
USE_EXSLT -DUSE_XSLT -DUSE_XMLMAPFILE -DUSE_WMS_LYR -DUSE_WFS_LYR
-DUSE_SOS_SVR -DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML
-DUSE_EXEMPI -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_MYSQL
-DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL -DUSE_OGR -DUSE_GEOS
-DHAVE_SYNC_FETCH_AND_ADD -DUSE_THREAD -DUSE_PROJ -DUSE_GD -DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_GIF -DUSE_ICONV -DUSE_JPEG -DUSE_GIF -DUSE_PNG
-DUSE_FREETYPE -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT
-DNEED_STRRSTR -DDISABLE_CVSID -I/usr/include/freetype2
-Irenderers/agg/include -I/usr/local/include -I/usr/local/include
-I/usr/local/pgsql/include -I/usr/include/mysql -g -pipe
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m32 -fasynchronous-unwind-tables -D_GNU_SOURCE
-D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv
-fPIC -fPIC -g -static-libgcc -fno-omit-frame-pointer -fno-strict-aliasing
-DMY_PTHREAD_FASTMUTEX=1 -I/usr/local/include
-I/usr/include/exempi-2.0/exempi -I/usr/include/libxml2
-I/usr/local/include/fribidi -I/usr/include/cairo -I/usr/include/glib-2.0
-I/usr/lib/glib-2.0/include -I/usr/include/pixman-1
-I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/apr-1
-I/usr/local/apache2/include mapcairo.c -o mapcairo.lo
libtool: compile: gcc -c -g -Wall -Wdeclaration-after-statement
-DUSE_PROJ_FASTPATHS -DMOD_WMS_ENABLED -DUSE_FASTCGI -DUSE_SVG_CAIRO
-DUSE_CAIRO -DUSE_FRIBIDI -DUSE_FRIBIDI2 -DUSE_EXSLT -DUSE_XSLT
-DUSE_XMLMAPFILE -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_SOS_SVR -DUSE_LIBXML2
-DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML -DUSE_EXEMPI -DUSE_WCS_SVR
-DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_MYSQL -DUSE_POSTGIS
-I/usr/local/apache2/include mapcairo.c -fPIC -DPIC -o .libs/mapcairo.o
mapcairo.c:367: error: expected specifier-qualifier-list before
'svg_cairo_t'
mapcairo.c: In function 'renderSVGSymbolCairo':
mapcairo.c:398: error: 'svg_cairo_status_t' undeclared (first use in this
function)
mapcairo.c:398: error: (Each undeclared identifier is reported only once
mapcairo.c:398: error: for each function it appears in.)
mapcairo.c:398: error: expected ';' before 'status'
mapcairo.c:399: error: 'status' undeclared (first use in this function)
mapcairo.c:399: warning: implicit declaration of function 'svg_cairo_render'
mapcairo.c:399: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:400: error: 'SVG_CAIRO_STATUS_SUCCESS' undeclared (first use in
this function)
mapcairo.c: In function 'freeSVGCache':
mapcairo.c:1041: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:1043: warning: implicit declaration of function
'svg_cairo_destroy'
mapcairo.c:1043: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c: In function 'msPreloadSVGSymbol':
mapcairo.c:1102: error: 'symbolObj' has no member named 'renderer_free_func'
mapcairo.c:1106: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:1113: warning: implicit declaration of function
'svg_cairo_create'
mapcairo.c:1113: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:1118: warning: implicit declaration of function 'svg_cairo_parse'
mapcairo.c:1118: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:1123: warning: implicit declaration of function
'svg_cairo_get_size'
mapcairo.c:1123: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c: In function 'msRenderRasterizedSVGSymbol':
mapcairo.c:1176: error: 'struct svg_symbol_cache' has no member named
'scale'
'rotation'
mapcairo.c:1213: error: 'struct svg_symbol_cache' has no member named 'svgc'
mapcairo.c:1213: error: 'SVG_CAIRO_STATUS_SUCCESS' undeclared (first use in
this function)
mapcairo.c:1224: error: 'struct svg_symbol_cache' has no member named
'scale'
mapcairo.c:1225: error: 'struct svg_symbol_cache' has no member named
'rotation'
make: *** [mapcairo.lo] Error 1
[root at sigservertemp mapserver-6.2.1]#
Someone can help me with this problem, I certainly have libsvg-cairo
compiled as indicated in the installation manual mapserver site
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130807/9aa2f7d1/attachment-0001.html>
