[mapserver-users] drawing multiple layers from postgis
Michael McInnis
mmcinnis59 at msn.com
Fri Aug 9 08:55:13 PDT 2013
Thomas,
Here is my complete map file when all the postgis layers are combined. Like I said, I can call all of these layersif I put just one layer in a .map file but can't get it to work with more than one.
Thanks!
MAP DEBUG 5 CONFIG "MS_ERRORFILE" "/media/D_Drive/www/gis/logs/error_file.log" EXTENT -126 25 -64 50 #EXTENT -123 47 -122 48 IMAGECOLOR 153 179 204 IMAGETYPE PNG24 SHAPEPATH data/ FONTSET data/fonts/fonts.list SIZE 1000 500 #SIZE 800 800 #SCALEDENOM 50000 UNITS DD PROJECTION "+proj=longlat +ellps=WGS84" END OUTPUTFORMAT NAME png DRIVER "AGG/PNG" MIMETYPE "image/png" IMAGEMODE RGBA EXTENSION "png" END WEB IMAGEPATH "/media/D_Drive/www/gis/tmp/" IMAGEURL "gis/tmp/" END
SYMBOL NAME "circle" TYPE ELLIPSE FILLED TRUE POINTS 1 1 END END
LAYER NAME states DATA STATES STATUS ON TYPE Polygon CLASS OUTLINECOLOR 255 255 255 COLOR 155 155 155 END # Class END # Layer
LAYER NAME business_rd1 CONNECTIONTYPE POSTGIS CONNECTION "host=localhost dbname=Business user=postgres password=xxxx port=5432" DATA "geom From business_rd1 as rd1 using unique id using srid=4326" PROCESSING "CLOSE_CONNECTION=DEFER" #MINSCALE 10000000 STATUS ON TYPE POINT CLASS SYMBOL 'circle' SIZE 2 COLOR 255 0 0 END END # Class END # Layer
LAYER NAME business_rd2 CONNECTIONTYPE POSTGIS CONNECTION "host=localhost dbname=Business user=postgres password=xxxxx port=5432" DATA "geom From business_rd2 as rd2 using unique id using srid=4326" PROCESSING "CLOSE_CONNECTION=DEFER" #MINSCALE 1000000 STATUS ON TYPE POINT CLASS SYMBOL 'circle' SIZE 2 COLOR 0 255 0 END END # Class END # Layer LAYER NAME business_rd3 CONNECTIONTYPE POSTGIS CONNECTION "host=localhost dbname=Business user=postgres password=xxxx port=5432" DATA "geom From business_rd3 as rd3 using unique id using srid=4326" PROCESSING "CLOSE_CONNECTION=DEFER" #MINSCALE 100000 STATUS ON TYPE POINT CLASS SYMBOL 'circle' SIZE 2 COLOR 0 0 255 END END # Class END # Layer
LAYER NAME business_rd4 CONNECTIONTYPE POSTGIS CONNECTION "host=localhost dbname=Business user=postgres password=xxxxx port=5432" DATA "geom From business_rd4 as rd4 using unique id using srid=4326" PROCESSING "CLOSE_CONNECTION=DEFER" #MINSCALE 10000 STATUS ON TYPE POINT CLASS SYMBOL 'circle' SIZE 2 COLOR 255 0 255 END END # Class END # LayerEND # Map File
Michael McInnis
6033 44th Ave. N.E.
Seattle, WA 98115
206 517-4701
> Date: Fri, 9 Aug 2013 17:44:02 +0200
> Subject: Re: [mapserver-users] drawing multiple layers from postgis
> From: thomas.bonfort at gmail.com
> To: mmcinnis59 at msn.com
> CC: mapserver-users at lists.osgeo.org
> https://github.com/mapserver/mapserver/issues/2922
> On 9 August 2013 17:40, Michael McInnis <mmcinnis59 at msn.com> wrote:
> > I'm pretty sure that END is correctly ending the Symbol Clause.
> > The odd thing about this is I can draw all four layers if I call them
> > separately but when I try to
> > call them through php only numbers 1 and 3 work. All layers were generated
> > the same way in
> > postgresql/postgis (see sql below).
> > I'm going to regenerate layers 2 and 4 just in case but I think it's a
> > problem with php/ms_script.
> > // All these work
> > http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business1.map&layers=business_rd1%20states&mode=map
> > http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business2.map&layers=business_rd2%20states&mode=map
> > http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business3.map&layers=business_rd3%20states&mode=map
> > http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business4.map&layers=business_rd4%20states&mode=map
> > // Half of these work
> > http://mapserver0/business.php?num=1 works
> > http://mapserver0/business.php?num=2 not
> > http://mapserver0/business.php?num=3 works
> > http://mapserver0/business.php?num=4 not
> > // All these work
> > // Create rounded lat lon table
> > Select count(*), round(cast(ST_X(geom) as numeric),2) as lon,
> > round(cast(ST_Y(geom) as numeric),2) as lat
> > Into business_rd2
> > From business_loc
> > Group By round(cast(ST_X(geom) as numeric),2), round(cast(ST_Y(geom) as
> > numeric),2)
> > Order By count Desc
> > // Add Geometry
> > Alter Table business_rd2 Add Column geom geometry(POINT,4326);
> > Update business_rd2 Set geom = ST_SetSRID(ST_MakePoint(lon,lat),4326);
> > Create Index indx_business_rd2_geom On business_rd2 Using GIST(geom);
> > // Now add a primary key named id to enable mapserver drawing
> > Alter Table business_rd2 Add Column id BIGSERIAL Primary Key;
> >> Date: Fri, 9 Aug 2013 12:23:52 +0200
> >> On 8 August 2013 20:16, Michael McInnis <mmcinnis59 at msn.com> wrote:
> >> > Hopefully, this is an easy one.
> >> > I'm trying to build a scale sensitive .map file using points from
> >> > postgis.
> >> > I can successfully draw the shapefile states with a single points layer
> >> > from
> >> > postgis.
> >> > However, if I add an additional points layer and attempt to draw it the
> >> > layer comes up blank.
> >> > If I remove the leading postgis points layer from the .map file the new
> >> > points layer will now display.
> >> > IE I can only draw the first occurrence of a postgis layer in the map
> >> > file.
> >> > How do you define multiple postgis layers so that you can pick and
> >> > choose
> >> > layers for display?
> >> > LAYER
> >> > NAME states
> >> > DATA STATES
> >> > STATUS ON
> >> > TYPE Polygon
> >> > CLASS
> >> > COLOR 155 155 155
> >> > END # Class
> >> > END # Layer
> >> > LAYER
> >> > NAME business_rd2
> >> > #MINSCALE 100000
> >> > STATUS ON
> >> > TYPE POINT
> >> > CLASS
> >> > SYMBOL 'circle'
> >> > SIZE 2
> >> > COLOR 255 0 0
> >> > END
> >> this END is bogus
> >> > END # Class
> >> > END # Layer
> >> > LAYER
> >> > NAME business_rd1
> >> > #MINSCALE 100000
> >> > STATUS ON
> >> > TYPE POINT
> >> > CLASS
> >> > SYMBOL 'circle'
> >> > SIZE 2
> >> > COLOR 255 0 0
> >> > END
> >> this one to
> >> > END # Class
> >> > END # Layer
> >> > _______________________________________________
> >> > mapserver-users mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130809/070efdb6/attachment-0001.html>
