[mapserver-users] drawing multiple layers from postgis
Michael McInnis
mmcinnis59 at msn.com
Fri Aug 9 09:15:17 PDT 2013
Nice work Thomas! That's got it.
http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business.map&layers=business_rd4%20states&mode=map
Now I can call any of the 4 from one .map file.
Now I just need to figure out how to call a specific layer via a .php file.
Thanks a lot, very subtle change there Adding STYLE in front of SYMBOL.
Michael McInnis
6033 44th Ave. N.E.
Seattle, WA 98115
206 517-4701
> From: bob.basques at ci.stpaul.mn.us
> CC: mapserver-users at lists.osgeo.org
> Date: Fri, 9 Aug 2013 16:02:31 +0000
> Subject: Re: [mapserver-users] drawing multiple layers from postgis
> Thomas,
> Oh man!! That's a subtle piece of info, any reason the END can't be left in there as a default somehow or at least ignored inside of the STYLE block, I can see this coming back to bite folks over time with the two different formats for SYMBOL/(and sometime END) combos.
> Bobb
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
> Sent: Friday, August 09, 2013 10:58 AM
> To: Michael McInnis
> Cc: mapserver-users at lists.osgeo.org
> third time's a charm :)
> LAYER
> NAME business_rd1
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost dbname=Business user=postgres password=xxxx port=5432"
> DATA "geom From business_rd1 as rd1 using unique id using srid=4326"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> #MINSCALE 10000000
> STATUS ON
> TYPE POINT
> CLASS
> STYLE
> SYMBOL 'circle'
> SIZE 2
> COLOR 255 0 0
> END #Style
> END # Class
> END # Layer
> symbol takes an END when you're defining a symbol , not when referencing it in a style.
> On 9 August 2013 17:55, Michael McInnis <mmcinnis59 at msn.com> wrote:
> > Thomas,
> > Here is my complete map file when all the postgis layers are combined.
> > Like I said, I can call all of these layers if I put just one layer in
> > a .map file but can't get it to work with more than one.
> > Thanks!
> > MAP
> > DEBUG 5
> > CONFIG "MS_ERRORFILE" "/media/D_Drive/www/gis/logs/error_file.log"
> > EXTENT -126 25 -64 50
> > #EXTENT -123 47 -122 48
> > IMAGECOLOR 153 179 204
> > IMAGETYPE PNG24
> > SHAPEPATH data/
> > FONTSET data/fonts/fonts.list
> > SIZE 1000 500
> > #SIZE 800 800
> > #SCALEDENOM 50000
> > UNITS DD
> > PROJECTION
> > "+proj=longlat +ellps=WGS84"
> > END
> > OUTPUTFORMAT
> > NAME png
> > DRIVER "AGG/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE RGBA
> > EXTENSION "png"
> > END
> > WEB
> > IMAGEPATH "/media/D_Drive/www/gis/tmp/"
> > IMAGEURL "gis/tmp/"
> > END
> > SYMBOL
> > NAME "circle"
> > TYPE ELLIPSE
> > FILLED TRUE
> > POINTS 1 1 END
> > END
> > LAYER
> > NAME states
> > DATA STATES
> > STATUS ON
> > TYPE Polygon
> > CLASS
> > OUTLINECOLOR 255 255 255
> > COLOR 155 155 155
> > END # Class
> > END # Layer
> > LAYER
> > NAME business_rd1
> > #MINSCALE 10000000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 255 0 0
> > END
> > END # Class
> > END # Layer
> > LAYER
> > NAME business_rd2
> > password=xxxxx port=5432"
> > DATA "geom From business_rd2 as rd2 using unique id using srid=4326"
> > #MINSCALE 1000000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 0 255 0
> > END
> > END # Class
> > END # Layer
> > LAYER
> > NAME business_rd3
> > DATA "geom From business_rd3 as rd3 using unique id using srid=4326"
> > #MINSCALE 100000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 0 0 255
> > END
> > END # Class
> > END # Layer
> > LAYER
> > NAME business_rd4
> > DATA "geom From business_rd4 as rd4 using unique id using srid=4326"
> > #MINSCALE 10000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 255 0 255
> > END
> > END # Class
> > END # Layer
> > END # Map File
> > Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
> >> Date: Fri, 9 Aug 2013 17:44:02 +0200
> >> From: thomas.bonfort at gmail.com
> >> To: mmcinnis59 at msn.com
> >> https://github.com/mapserver/mapserver/issues/2922
> >> On 9 August 2013 17:40, Michael McInnis <mmcinnis59 at msn.com> wrote:
> >> > I'm pretty sure that END is correctly ending the Symbol Clause.
> >> > The odd thing about this is I can draw all four layers if I call
> >> > them separately but when I try to call them through php only
> >> > numbers 1 and 3 work. All layers were generated the same way in
> >> > postgresql/postgis (see sql below).
> >> > I'm going to regenerate layers 2 and 4 just in case but I think
> >> > it's a problem with php/ms_script.
> >> > // All these work
> >> > s1.map&layers=business_rd1%20states&mode=map
> >> > s2.map&layers=business_rd2%20states&mode=map
> >> > s3.map&layers=business_rd3%20states&mode=map
> >> > s4.map&layers=business_rd4%20states&mode=map
> >> > // Half of these work
> >> > http://mapserver0/business.php?num=1 works
> >> > http://mapserver0/business.php?num=2 not
> >> > http://mapserver0/business.php?num=3 works
> >> > http://mapserver0/business.php?num=4 not
> >> > // All these work
> >> > // Create rounded lat lon table
> >> > Select count(*), round(cast(ST_X(geom) as numeric),2) as lon,
> >> > round(cast(ST_Y(geom) as numeric),2) as lat
> >> > Into business_rd2
> >> > From business_loc
> >> > Group By round(cast(ST_X(geom) as numeric),2),
> >> > numeric),2)
> >> > Order By count Desc
> >> > // Add Geometry
> >> > Alter Table business_rd2 Add Column geom geometry(POINT,4326);
> >> > Update business_rd2 Set geom =
> >> > ST_SetSRID(ST_MakePoint(lon,lat),4326);
> >> > Create Index indx_business_rd2_geom On business_rd2 Using
> >> > GIST(geom);
> >> > // Now add a primary key named id to enable mapserver drawing
> >> > Alter Table business_rd2 Add Column id BIGSERIAL Primary Key;
> >> >> Date: Fri, 9 Aug 2013 12:23:52 +0200
> >> >> postgis
> >> >> On 8 August 2013 20:16, Michael McInnis <mmcinnis59 at msn.com> wrote:
> >> >> > Hopefully, this is an easy one.
> >> >> > I'm trying to build a scale sensitive .map file using points
> >> >> > from postgis.
> >> >> > I can successfully draw the shapefile states with a single
> >> >> > points layer from postgis.
> >> >> > However, if I add an additional points layer and attempt to draw
> >> >> > it the layer comes up blank.
> >> >> > If I remove the leading postgis points layer from the .map file
> >> >> > the new points layer will now display.
> >> >> > IE I can only draw the first occurrence of a postgis layer in
> >> >> > the map file.
> >> >> > How do you define multiple postgis layers so that you can pick
> >> >> > and choose layers for display?
> >> >> > LAYER
> >> >> > NAME states
> >> >> > DATA STATES
> >> >> > STATUS ON
> >> >> > TYPE Polygon
> >> >> > CLASS
> >> >> > COLOR 155 155 155
> >> >> > END # Class
> >> >> > END # Layer
> >> >> > LAYER
> >> >> > NAME business_rd2
> >> >> > #MINSCALE 100000
> >> >> > STATUS ON
> >> >> > TYPE POINT
> >> >> > CLASS
> >> >> > SYMBOL 'circle'
> >> >> > SIZE 2
> >> >> > COLOR 255 0 0
> >> >> > END
> >> >> this END is bogus
> >> >> > END # Class
> >> >> > END # Layer
> >> >> > LAYER
> >> >> > NAME business_rd1
> >> >> > #MINSCALE 100000
> >> >> > STATUS ON
> >> >> > TYPE POINT
> >> >> > CLASS
> >> >> > SYMBOL 'circle'
> >> >> > SIZE 2
> >> >> > COLOR 255 0 0
> >> >> > END
> >> >> this one to
> >> >> > END # Class
> >> >> > END # Layer
> >> >> > _______________________________________________
> >> >> > mapserver-users mailing list
> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130809/0c8e3512/attachment-0001.html>
