[mapserver-users] vector Symbol and anchorpoint
thomas bonfort
thomas.bonfort at gmail.com
Sun Aug 11 05:15:16 PDT 2013
As you're not showing what you would like to obtain, nor the mapfile
you are using to generate those images it is difficult to be of much
help. I have added a test in
https://github.com/mapserver/msautotest/commit/89d59a49586dc3192dfd2f67bd1a751f0900e36f
that mimics what I guess you would like to obtain, and for me shows
that anchorpoint seems to be working as expected.
thomas
On 11 August 2013 13:07, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> thx for response.
> I try to set this symbol:
> SYMBOL
> NAME "test"
> TYPE vector
> FILLED TRUE
> POINTS
> 0.0 0.0
> 1.0 0.0
> 0.5 0.0
> 0.5 0.5
> END
> ANCHORPOINT 0.0 0.0
> END
> But mapserver seem move the line by 0.5.
> I show in the attached image (img1) the problem.
> The filled green is the real polygon.
> Instead the red is the symbol I try to define with "test".
> As you can see the red line is not in the exact outline but 0.5 moved.
> I notice also that if I define this other kind of symbol:
> SYMBOL
> NAME "chiodo"
> TYPE vector
> FILLED TRUE
> POINTS
> 0.0 0.0
> 1.0 0.0
> 0.5 0.0
> # 0.5 0.5
> END
> ANCHORPOINT 0.0 0.0
> END
> Where I comment the perpendicul segment,
> the result is a red line exactly on the outline.
> I show this in the img2 attacched.
> So mapserver seem move the symbol when there is a perpendicular segment.
> Is this a bug or I don't understand how work the symbols ?
> Thx,
> Andrea.
> 2013/8/11 thomas bonfort <thomas.bonfort at gmail.com>
>> try defining the points of your vector symbol such that min(x)=min(y)=0
>> On 11 August 2013 10:30, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > Hi,
>> > I'm having trouble try.ing use the anchorpoint with a vector symbol.
>> > Is this working with vectors ?
>> > This is what I'm try to do:
>> > SYMBOL
>> > NAME "test"
>> > TYPE vector
>> > FILLED TRUE
>> > POINTS
>> > 0.5 1.0
>> > 0.5 0.75
>> > 0.0 0.75
>> > 1.0 0.75
>> > END
>> > ANCHORPOINT 0.0 0.0
>> > END
>> > The anchorpoint seem always set to the 0.5 0.5 position.
>> > I'm use the trunk version of mapserver.
>> > Andrea Peri
>> > qwerty àèìòù
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
